pocket mode issue
  1. AnkKod
    Cupcake Dec 7, 2018
    AnkKod , Dec 7, 2018 :
    I have pocket mode on, observed this couple of times that even after getting phone out of my pocket it still stays in pocket mode so single tap on screen doesn't work, with that even power button also doesn't work. This is observed when there was enough light in the surrounding.
  2. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Dec 7, 2018
    NeVeR_SeTTLe , Dec 7, 2018 :
    Pocket mode simply means that it won't turn on accidentally when it's in your pocket.
    Did you try to turn off and turn on pocket mode in Settings and then try again?
  3. AnkKod
    Cupcake Dec 7, 2018
    that's exactly my point.
    After the first time it happened I tried that but apparently it didn't solve the issue.
  4. NeVeR_SeTTLe
    Did you try to wipe cache from Recovery?
  5. AnkKod
    Cupcake Dec 7, 2018
    no. didn't try that.
  6. NeVeR_SeTTLe
  7. ToothFairy
    Cupcake Dec 7, 2018
    NeVeR_SeTTLe likes this.
  8. Karamai
    Cupcake Dec 7, 2018
    Karamai , Dec 7, 2018 :
    I have the same exact issue. Pocket mode seems to have a "delay" before alowing tap to unlock.
    Did the cache wipe suggested by support but it didn't solve the problem.
  9. adriq89
    Cupcake Aug 22, 2019
    adriq89 , Aug 22, 2019 :
    same here. I even rolled back to Oreo and re installed Pie to ensure all is set from scratch and the issue persists
  10. Starcommander
    KitKat Aug 22, 2019
    Starcommander , Aug 22, 2019 :
    Have you applied scratch guard?
