7
pocket mode
  1. MERSON Raja
    Froyo Jul 14, 2019
  2. Photoman9988
    KitKat Jul 14, 2019
    H1560482217655 likes this.
  3. D1562744746854
    Cupcake Jul 18, 2019
  4. ejazcool1
    Donut Jul 18, 2019
    ejazcool1 , Jul 18, 2019 :
    fingerprint sensor automatically disable whenever I take my mobile out from my pocket...
    it says maximum attempt made to unlock device
    sakearzoo, Beast2015, Csevege and 6 others like this.
  5. Rajan06
    Froyo Jul 18, 2019
    Rajan06 , Jul 18, 2019 :
    same happens to me also so switch to face unlock.
  6. G1533957632788
    Cupcake Jul 30, 2019
  7. Rajan06
    Froyo Jul 30, 2019
  8. G1533957632788
    G1533957632788 , Jul 30, 2019 :
    so doesnt OnePlus 7 or 7 pro have proximity sensor?
  9. Rajan06
    Froyo Jul 30, 2019
    Rajan06 , Jul 30, 2019 :
    G1533957632788
    No
    Due to bezel less display, there is no space for such sensor so they use camera for such function( example while calling)
    Edited: after many research by me I have found proximity sensor under the display
    1. sensor in working mode
    2. when it's turned off
    TAMIL_VANAN likes this.
  10. G1533957632788
    Now I understand lol..thanks for the reply and information too
  11. Rajan06
    Froyo Jul 30, 2019
    You're welcome
  12. AdityaAgrawal516
    Froyo Jul 31, 2019
    AdityaAgrawal516 , Jul 31, 2019 :
    what nonsense! it has ultra sonic proximity sensor in it. Dont you know? check it out through engineering mode. All sensirs are under the display. Its not a big thing.
  13. Rajan06
    Froyo Jul 31, 2019
    Rajan06 , Jul 31, 2019 :
    show me the screenshot
  14. TarveshChauhan
    Froyo Jul 31, 2019
    TarveshChauhan , Jul 31, 2019 :
    yeah we want pocket mode or disable lock feature
    maximum time its happening to me phone is active and too many finger scan attempted msg is coming
    pgrey and Akash Rajendran R like this.
  15. Swejuggalo
    KitKat Jul 31, 2019
    pgrey likes this.
  16. pgrey
    Ice Cream Sandwich Jul 31, 2019
    pgrey , Jul 31, 2019 :
    Hmm, thanks for the link, @Swejuggalo , interesting stuff.
    I have never been a big fan of the bezel-less design, this being one more reason.
    I ride a lot (road cycling), and my OP phones typically are in a ziploc, while pedaling, in a jersey pocket.
    This was a non-issue, with older (long string of WinPhones) phones, and my 5T and 6, but my OP7 Pro is a different story.
    I was seeing "odd screen time usage", leading to some pretty significant battery drain, say if I went out for a 3 hour ride, I would see values such as 137 minutes of "screen on time", even though I had never actually used the device.
    I also was getting "locked out" of the fingerprint sensor, and scratching my head on that one (since it's the easy way to unlock it, through the ziploc-bag), it seems to happen maybe 75% of the time (on any length ride).
    I think OP needs to do SOMETHING here. Obviously, they're trying to figure out which "fix" is going to cause the least "bad reaction", from the user-base.
    Personally, I wish it just had a darn top-bezel, but that's obviously not an option, with the 7-series anyway...
    The "slider setting" would probably be the next most useful solution, but it'd have to accessible, on the lock screen, in order to "actually be useful", IMO.
    Just "not dealing with this" is a bad move, entirely, if you ask me; I bet a lot of these "fingerprint lock-out" and "crazy screen time usage" complaints lead straight back to this...
    Jevin Shah and Akash Rajendran R like this.
  17. Rajan06
    Froyo Jul 31, 2019
    sorry for inconvenience. Actually you were right
  18. justinbartley77
    Cupcake Aug 1, 2019
    justinbartley77 , Aug 1, 2019 :
    Would really like Pocket Mode on my OnePlus 7 on the next update. Keeps opening apps and changing settings when in my pocket. Worked fine with my OnePlus 3t.
  19. AdityaAgrawal516
    Froyo Aug 6, 2019
  20. ssuthar91
    Cupcake Aug 12, 2019
