6
[Submitted] Podcast playback issue
Thread Status:
Not open for further replies.
  1. daviporciuncula
    Eclair Dec 5, 2016
    daviporciuncula , Dec 5, 2016 :
    Several podcast apps, Pocketcasts, CastBox, Podcast addict, have issues where the progress bat won't update , staying stuck. The forward/rewind buttuns won't function properly, often finishing episodes. The eps also finish in the middle of playback, and scrollimg manually in the progression bar won't work on the correct time. MP3 playback on the music app or through Google Drive sometimes presents with the same issues. Resuming episodes also does at the wrong times...
    Cleanstream, lfcrd, lakanta and 3 others like this.
  2. vincenam
    Donut Dec 5, 2016
    vincenam , Dec 5, 2016 :
    I have this too with Pocket Casts and Podcast Addict after Nougat update.
  3. bobblydrillboy
    Cupcake Dec 7, 2016
    daviporciuncula likes this.
  4. vincenam
    Donut Dec 8, 2016
    vincenam , Dec 8, 2016 :
    Player FM is the only podcast player that appears to work properly for me now.
  5. bobblydrillboy
    Cupcake Dec 9, 2016
  6. AcmE85
    Ice Cream Sandwich Dec 9, 2016
    AcmE85 , Dec 9, 2016 :
    I had the same issue and discovered that it is gone after disabling "volume boost" inside Pocket Casts and restarting the app. Must be some changes to the audio system which are causing this bug.
  7. Deactivated User
    Dec 10, 2016
  8. G_Jacob_Lipsey_cswC
    Cupcake Dec 13, 2016
  9. Deactivated User
    Dec 14, 2016
  10. lahnipm
    Cupcake Dec 14, 2016
  11. daviporciuncula
    Eclair Dec 15, 2016
    daviporciuncula , Dec 15, 2016 :
    disabling trim and volume boost restores the progression bar functionality, however the skipping/resuming playback issue persists. As the one finishing the ep near the end out of the blue...
  12. daviporciuncula
    Eclair Dec 15, 2016
  13. andreabergia
    Cupcake Dec 19, 2016
    G_Jacob_Lipsey_cswC likes this.
  14. PhilipTruong
    Donut Dec 20, 2016
    PhilipTruong , Dec 20, 2016 :
    I got this reply from Shifty Jelly, developer of Pocket Casts "We did had few user having some issue with the same handset with playing progress and skipping and the developer here has worked out after few test that it is not an issue on our side. We have looked into the issue and figured it is something on the OnePlus 3 needs to look into about their setting."
  15. lfcrd
    Cupcake Dec 28, 2016
    lfcrd , Dec 28, 2016 :
    I also have this issue on the stable OOS builds since 3.2.7. The only podcast app I have found that doesn't have the issue is Podcast Republic, as they use ExoPlayer rather than the standard Android media player. The issue is present on Pocketcasts, Podcast Addict, etc. The only way to get around the issue I have found is to use a custom ROM until it is fixed by OnePlus. I uploaded a video of the issue here
  16. vincenam
    Donut Dec 28, 2016
  17. Deactivated User
    Dec 28, 2016
  18. daviporciuncula
    Eclair Dec 28, 2016
    daviporciuncula , Dec 28, 2016 :
    The turning off automatically? Will update and report here (Y)
  19. Deactivated User
    Dec 28, 2016
  20. daviporciuncula
    Eclair Dec 28, 2016
    The issue of finishing some podcast persists on beta 10. Someone suggested it was a encoding issue on part of the publisher? Has anyone have any idea? Volume boost/trim can be toggled again though :)
