pop up camera not sitting flush
  1. sime27 Froyo Jun 16, 2019
    sime27, Jun 16, 2019 :
    I've used the front pop up camera a few times, now I've noticed it's not sitting back completely flush.
    1 side is sitting in the handset more than the other.
    Anyone else had this problem?
  2. kevinplus2 Honeycomb Jun 16, 2019
  3. sime27 Froyo Jun 17, 2019
    sime27, Jun 17, 2019 :
    It's difficult to get a good picture.. But the left side of the camera head sinks into the chassis a little bit further than the other side. Which doesn't look good and is becoming a dust/fluff trap
  4. kevinplus2 Honeycomb Jun 17, 2019
  5. TomekDarda Froyo Jun 18, 2019
    TomekDarda, Jun 18, 2019 :
    Mine too sits just a liiiiitle bit lower than the rest of the chassis. Almost not recognizable in fact. A bit more on the left side, yeap. I guess I don't really mind anymore (I did bother for 2 hours in the style of "oh no, a brand new device, is there anything wrong, have I done it?") and expect quite a lot of users having this and not even noticing. Esp. when using a case.
    dantay101, Drewgaren and kevinplus2 like this.
  6. sime27 Froyo Jun 27, 2019
    sime27, Jun 27, 2019 :
    Anyone else with this issue? Or does my handset have a defect
  7. Milehigherik Cupcake Jun 28, 2019
  8. dantay101 Donut Jun 28, 2019
    dantay101, Jun 28, 2019 :
    I noticed this too......it sits a tiny bit lower on the left hand side on mine too.
  9. sime27 Froyo Jun 28, 2019
    sime27, Jun 28, 2019 :
    Worth reporting you think? It's annoying seeing it and it keeps trapping dust
  10. dantay101 Donut Jun 28, 2019
    I think dust will always get in around that area as the seal is at the bottom of the camera module so whatever lint is floating around in your pocket will find its way in regardless. If you look at other units I’m guessing they will all be like it to a greater or lesser degree. I’ve only had mine a week and am in the UK so can return for any reason so I’ll have a look at some other units in the EE store when I’m passing. If theirs are perfect I’ll return this one.
  11. sime27 Froyo Jun 29, 2019
    sime27, Jun 29, 2019 :
    OK let me know what you find out
  12. G_Larry_Underhill_GAXa Gingerbread Jun 29, 2019
  13. DeathMoJo Gingerbread Jun 29, 2019
