24
ROM [PORT] OxygenOS 3.X.X [DEODEXED] [MAGISK/ROOT/XPOSED]
Which one do you use?
  1. Stock
  2. SuperX
  3. MagiX
Results are only viewable after voting.
  1. F_Felipe_Julio_JirN
    Cupcake Nov 3, 2016
    F_Felipe_Julio_JirN , Nov 3, 2016 :
    niiice
  2. bright_wal
    Honeycomb Nov 4, 2016
    bright_wal , Nov 4, 2016 :
    I am really liking the ROM a lot. I'm getting somewhere between 5-5.5 hours sot.
    The stability is so good. It feels so much smoother compared to the most stable ROM for our phone.
    I wish there was custom kernel for this ROM. And faster charging. The dev might get this working soon.
    THE CAMERA IS THE BEST ON OPO TILL DATE. PERIOD.
    Simple. It's based on oos 3 proprietary Hal's of op and the Hal's that comes close to this sultan that's based on oos 1 Hal's.
    this ROM is amazing. But doesn't have multirom.
    for me these sacrifices are worth what I get and can live peacefully with this ROM.
    if you wanna settle down from flashing. this might be it.
  3. 20209641
    Eclair Nov 4, 2016
    20209641 , Nov 4, 2016 :
    [QUOTE ver="bright_wal, post: 15358246, member: 807360"]I am really liking the ROM a lot. I'm getting somewhere between 5-5.5 hours sot.
    if you wanna settle down from flashing. this might be it.[/QUOTE]
    i face very slow Charing...what about ur Charing time??
  4. kartike4u
    Ice Cream Sandwich Nov 6, 2016
    kartike4u , Nov 6, 2016 :
    When I was on RR marshmallow in kernel auditor I was getting the option of zzmove and many other governors and also I was able to reduce the global offset (voltage) to -25mV but I'm not getting any option for this at all in oxygen os 3.1.3.
    My device is opo and many other options are not available..
    I really want to change the global offset but I can't ...help it's increased my battery life very much
  5. DEADLYiNDIAN
    Froyo Nov 6, 2016
    DEADLYiNDIAN , Nov 6, 2016 :
    Right now there is no custom kernel yet.
  6. kartike4u
    HOW CAN I CHANGE GLOBAL OFFSET
  7. costi_pit2002
    Gingerbread Nov 6, 2016
    costi_pit2002 , Nov 6, 2016 :
    Dude, are you f*$%ing retarded?
    THERE IS NO CUSTOM KERNEL AR ANY OTHER WAY TO CHANGE GLOBAL OFFSET FOR THIS ROM!
    Unless you make your own from scratch.
    Cheers.
  8. hammoudix1
    Eclair Nov 10, 2016
  9. DEADLYiNDIAN
    Froyo Nov 10, 2016
    pinto123 and hammoudix1 like this.
  10. hammoudix1
    Eclair Nov 10, 2016
  11. hammoudix1
    Eclair Nov 10, 2016
  12. DEADLYiNDIAN
    Froyo Nov 10, 2016
    hammoudix1 and costi_pit2002 like this.
  13. costi_pit2002
    Gingerbread Nov 10, 2016
    costi_pit2002 , Nov 10, 2016 :
    If you deactivate one of the sims, does it speed up the network conection time?
    Also, any chance bringing back software buttons without GravityBox?
    Thanks.
  14. DEADLYiNDIAN
    Froyo Nov 10, 2016
    DEADLYiNDIAN , Nov 10, 2016 :
    Network fix is coming on the next port update.
    You can enable soft keys from Settings > buttons > On-screen navigation bar
    and flash the disabe hw keys zip from op.
    siva-kumar likes this.
  15. costi_pit2002
    Yes, my bad.
    What i wanted to ask is the key swap for software buttons.
    Or is that available too?
    Thanks for all your work!
    hammoudix1 likes this.
  16. hammoudix1
    Eclair Nov 10, 2016
    hammoudix1 , Nov 10, 2016 :
    it's available too in the sittings
    costi_pit2002 likes this.
  17. hammoudix1
    Eclair Nov 10, 2016
  18. DEADLYiNDIAN
    Froyo Nov 11, 2016
    DEADLYiNDIAN , Nov 11, 2016 :
    Yep it's below that.
    It is being tested so be patient :)
    rphlfjrd likes this.
  19. pinto123
    Honeycomb Nov 11, 2016
    pinto123 , Nov 11, 2016 :
    3.1.4 ..Waiting...
    3.1.3 very stable and its my daily driver now. I like this..
    3.1.4 wont hurt either....;)o_O
  20. bero74
    Eclair Nov 11, 2016
    bero74 , Nov 11, 2016 :
    Nice ROM indeed!
    I was on 3.1.3 stock ROM for a while and it's verry stable and solid.
    One thing that I noticed though is that when using the hardware buttons the launcher icon grid size was 5x4 and when using software keys it was the standard(?) 4x4. Strange ... :rolleyes:
    I tried to connect through adb to play with different DPI settings, but it seems that it's not supported in the ROM?
    Will the 3.1.4 release be patched for the dirty cow vulnerability?
