49
Post Your OnePlus Homescreen
  1. thisguysayswht
    Ice Cream Sandwich Feb 27, 2015
  2. amandanguyen93
    Honeycomb Feb 27, 2015
    rufo99 and eckbauer like this.
  3. Renjith johnson
    Cupcake Feb 27, 2015
  4. Renjith johnson
  5. skyrocket
    Gingerbread Feb 27, 2015
    DavidBiate and eckbauer like this.
  6. Slatter191
    Lollipop Feb 27, 2015
    eckbauer likes this.
  7. Slatter191
    thisguysayswht likes this.
  8. eckbauer
    KitKat Feb 27, 2015
    Slatter191 likes this.
  9. eckbauer
    KitKat Feb 27, 2015
  10. Slatter191
  11. eckbauer
    KitKat Feb 27, 2015
    eckbauer , Feb 27, 2015 :
    No problem ......Wallpaper :)
  12. Kevtron
  13. Slatter191
  14. Slatter191
    Slatter191 , Feb 27, 2015 :
    Oh my bad......yr one geek........WP= Wallpaper ;)
  15. Zerone01
  16. Zerone01
  17. eckbauer
    KitKat Feb 27, 2015
    @Slatter191
    Using Nova Prime.
    You can place widgets in the Dock. Zooper widgets to.
    You can not have a Dock on only one home screen the Dock will be on all HS's.
    Here are some screen shots.(Widgets in Dock)
    . Screenshot_2015-02-27-12-09-58.png Screenshot_2015-02-27-12-05-58.png Screenshot_2015-02-27-12-04-02.png Screenshot_2015-02-27-12-02-59.png
    Hope that helps you.
    Ceasedd and Slatter191 like this.
  18. Slatter191
    Thanks eckbauer for the screen shots and views.
    Fail to understand this ........ You can not have a Dock on only one home screen the Dock will be on all HS's. ?
    In the 1st one, don't get options like you get.......only Edit, Remove, App info........no disable padding, bring to front and back.
    In the 2nd one you have a small dock on the rt corner correct?
    What icon style did you use?
    How did you bring the notification bar in the 3rd?
    Best Regards!
  19. eckbauer
    KitKat Feb 27, 2015
    The Dock will show on all Home screens. You can only hide or show the Dock. In Nova settings.
    When placing widgets in Dock you must resize them to fit. Only sometimes.
    In Nova settings tick allow overlapping of widgets.
    Just drag and drop the widget into the Dock and resize it to fit.
    Icon style is not important.
    This might help you.
    Safiy, Ceasedd and Slatter191 like this.
  20. Slatter191
    Thanks eckbauer you are one genius.
    Best Regards!
    Ceasedd and eckbauer like this.
