11
Power Bank Test Results
  1. Afzal Khan
    KitKat Apr 8, 2015
    bishs likes this.
  2. Zachsaxe
    Lollipop Apr 8, 2015
    Zachsaxe , Apr 8, 2015 :
    For the output you have two factors. One the app or plug could be Messing up and when the phone is on you only get half the amps. 2. The cable could be bad
  3. rsagdulla
    Gingerbread Apr 8, 2015
    rsagdulla , Apr 8, 2015 :
    Look, it is told that the power bank has 10.000 in 3.7, but when you connect your OPO, the power bank converts that 3.7v in 5v, because only 5v can charge the phone, because of that convertation there is a loose... It is physics)
    j7urner likes this.
  4. BigRedBaron
    Honeycomb Apr 8, 2015
    BigRedBaron , Apr 8, 2015 :
    I don't think it works that way
  5. bishs
    bishs , Apr 8, 2015 :
    Thanks for the nonconstructive critique of my methods, my friend. This was, of course, not a scientific study. Also, if a product is advertised as 10000mAh, a normal consumer will assume that it will completely charge their 3100mAh battery at least three complete times. I don't give a hoot if in lab conditions it causes the earth's tilt to change if its real life performance is not as expected by a normal person.
    sfomin and ryanscottbaker like this.
  6. rsagdulla
    Example, bank has 10.000 in 3.7v, ic you want its charging you "X" device in 37v, the just divide the capacy by 10, the rusult will be 1000 in 37v. Something like this...
    bishs likes this.
  7. bishs
    I understand what you're saying. This was just a average consumer charge-discharge cycle test ti see the irl performance. :)
    firefly5 likes this.
  8. CasperTFG
    KitKat Apr 8, 2015
    CasperTFG , Apr 8, 2015 :
    I begging to believe what you pay for. My OPO takes approximately over two hours to charge. I went from being able to charge it three times with the power bank to only 1.5 before I had to charge it up again.
  9. bose301s
    Ice Cream Sandwich Apr 8, 2015
    bose301s , Apr 8, 2015 :
    It has 10000 mAh, they all rate them by the size of the battery used inside. That's standard practice, not just by OP but the entire industry, that you're too dense to understand this shouldn't make a difference.
    j7urner likes this.
  10. bishs
    Like some of the commentators said, I might need the PB to go through a few charge-discharge cycles before it achieves full capacity. I'll update my results in a couple of weeks' time if I see this happen.
  11. boxter
    boxter , Apr 8, 2015 :
    To me sounds like you tried to measured the capacity of the bucket filling it to the top, while the bucket had a hole in the bottom of it. Phone should be off at all times during changing to give accurate reading
    gusuraman likes this.
  12. johnnymartz3
    Jelly Bean Apr 8, 2015
    johnnymartz3 , Apr 8, 2015 :
    Don't forget that if ur phone was powered on the whole time u were using power there, and u lost some power during transmission too. That, combined with the other factors ppl have mentioned could explain ur missing capacity
  13. bishs
    That sounds reasonable - I'll do that the next time to make it more accurate.
    boxter likes this.
  14. d1beats
  15. guijan12
    KitKat Apr 8, 2015
  16. boxter
    I will try to run some tests too, I have both of them now (white and Black) :)
  17. matanp
    matanp , Apr 8, 2015 :
    3 hours is a lot for 2A output
    i can charge my phone in about 1.5 - 2 hours using a wall charger which is 2.1A
    can you try to check the charge time while the phone is off? most users will use the phone more when it's connected to a power bank than to a wall charger, and this can change the test results.
    p.s.
    i wouldn't count on an app for telling me the amperage of the charging
    bishs likes this.
  18. meatandy
    Oreo Apr 8, 2015
    meatandy , Apr 8, 2015 :
    Won't it improve with some run/ charge cycles on it!
    #38
    bishs likes this.
  19. bishs
    That seems to be the general recommendation.
    #39
    meatandy likes this.
  20. Kernan
    Kernan , Apr 8, 2015 :
    The battery is probably not perfectly efficient when transferring power from its battery to your phone. Some power is most likely lost through heat and other factors during the charge. You should always expect that the battery will not be able to output all of its stored power with perfect efficiency.
    #40
