2
Power menu: Google Home devices not found via OnePlus Nord 2
  1. #1
    dra_graff and Richard.C like this.
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Aug 18, 2021
    Bobbie63 and McJader like this.
  3. Z1532129572756 , via OnePlus Nord 2 , Aug 23, 2021 :
    Thanks for the suggestions. I read them and it talks about Google Home app. My home app is working fine, I can see all my linked devices - but those devices are not showing in the power menu feature.
  4. Bobbie63
    Marshmallow Aug 23, 2021
    Bobbie63 , Aug 23, 2021 :
    You can add them in the power menu by using the 3dot menu
    Caomhin likes this.
  5. Z1532129572756 , via OnePlus Nord 2 , Aug 23, 2021 :
    Yes, I tried that. I was able to successfully add my Mi Home App and it's device. But I can't see any devices to add from my Google Home app.
  6. Bobbie63
    That’s weird, they all show up with me, don’t know what criteria the devices must have to show up automatically in the power menu because they don’t show up all tbh, just the Google ones and the Hue. Others I have to add manually but they do show up all.
    but in your first screenshot, the purifier and bedroom speaker can’t be controlled from Google home either, they are not connected I think. I guess the living room light and the bedroom light are the only ones that show up in the power menu?
    Caomhin likes this.
  7. Z1532129572756 , via OnePlus Nord 2 , Aug 23, 2021 :
    Yeah. It is weird. I have almost 15 devices in my google home app - none of them are showing in the power menu - even the lights. As you can see in my 2nd screenshot, I highlighted the home app drop down but it showed nothing. I'm using Nord 2 with Oxygen OS 11.3
    L1622380822021 and Bobbie63 like this.
  8. Bobbie63
    Unfortunately I have the Nord one, which all is a bit different, so I’m a bit out of options.
    the second screenshot, is this from the power menu, because this looks sure different from what I’ve got
  9. Z1532129572756 , via OnePlus Nord 2 , Aug 23, 2021 :
    Yes, it's from the power menu - after choosing "add controls" then "select other apps" option. Thanks a lot for checking and suggesting possible answers.
    Bobbie63 likes this.
  10. Bobbie63
    Ah thank, I found it. It is the same
  11. Bobbie63
    But what I don’t understand. Take that airpurifier, looks like it’s not connected to Google home.
    there is no control below like with the lights.
    Caomhin likes this.
  12. Z1532129572756 , via OnePlus Nord 2 , Aug 23, 2021 :
    It's connected. On/Off function is available when you open it. but I don't worry about that since my Mi Home app is working in my power menu.
  13. Bobbie63
    It’s just that I noticed the on/off function isn’t available from the Google Home Screen which normally should I think. That’s why I thought it could had to do with your issue
    Caomhin likes this.
  14. L1622380822021
    Cupcake Aug 28, 2021
    L1622380822021 , Aug 28, 2021 :
    I have exactly the same issue on my Nord2.
    Before all my Google smart home devices worked fine in the power menu on my Samsung s10e.
    dra_graff likes this.
  15. dra_graff
    Donut Sep 28, 2021
    AKSHAT RAJ likes this.
  16. Klikmie
    Cupcake Oct 25, 2021
    Klikmie , Oct 25, 2021 :
    Have the same problem. Google Home shows up, but no devices appear (screenshot). Earlier I somehow hot it to show some devices, but no lamps (Hue of IKEA) other linked devices. Everything works pefectly in the home app itself.
    L1622380822021 likes this.
  17. g.ekkelenkamp
    Cupcake Nov 2, 2021
    g.ekkelenkamp , Nov 2, 2021 :
    Thanks a lot! This worked for me using a Nord 2. Looks like a bug with the nord 2 and google home. After installing and configuring the app once, the power menu works like a charm. Deleted the app afterwards and haven't encountered any issues.
  18. AKSHAT RAJ , via OnePlus Nord 2 Gray Sierra , Nov 26, 2021 :
    I too have the same issue but this method first solve the issue for me :_(
