power off alarm doesn't work even when it is enabled!
  1. nads_sk
    Cupcake Sep 13, 2020
    nads_sk , Sep 13, 2020 :
    The power off alarm doesn't work for me even when it is enabled. I have tried clearing Clock app's data but no luck. I also tried clearing all the permission amd again allowing them. I reckon the problem is when I allow "Power off alarm permission" it doesn't reflect in "See all apps with this permission" option. that's why its not working. plz help.
    for better understanding attached are the screenshots.
  2. drl431
    Nougat Sep 13, 2020
    drl431 , Sep 13, 2020 :
    Try changing the power off alarm switch this way:
    Clock app > tap gear > Power off alarm.
    If that does not help, turn off the switch, restart the phone, then turn it back on.
    the_o2 likes this.
  3. the_o2
    User of the Year 2018 Sep 13, 2020
    the_o2 , Sep 13, 2020 :
    Hi mate,
    Make sure this setting is enabled in the clock app settings
    And for your last screenshot (power of alarm) where the clock app is not showing,
    Click on the 3 dots on the right corner and enable show System, now you we will be able to see the clock app
    drl431 likes this.
  4. nads_sk
  5. nads_sk
    thanks I kater figured it out. But it still doesn't work!!
  6. nads_sk
    tried that too
  7. the_o2
    Clear the storage data of the clock app and restart your phone once and see if it fixes the issue
  8. nads_sk
    tried but still not working!!
  9. the_o2
  10. Soham_Zemse
    Cupcake Oct 29, 2020
