power off button
  1. Manideep peela
    Cupcake May 6, 2020
  2. Scherpenseel
    KitKat May 6, 2020
  3. Batman360
    Accessory Tester, OnePlus TV Product Ninja 2021 May 6, 2020
    Manideep peela likes this.
  4. Paschfire , via OnePlus Community App , May 6, 2020 :
    Not sure what you want us to suggest? Other than you should take or send your device into an authorized OnePlus Service Center for inspection and price quote for possible repairs.
  5. ronaksworld
    Jelly Bean May 6, 2020
    ronaksworld , May 6, 2020 :
    Did you dissamble your device?? After which it stopped??
  6. Manideep peela
    Cupcake May 6, 2020
    Manideep peela , May 6, 2020 :
    how can we will dissamble .
    can you suggest me
  7. ronaksworld
    About dissambling you need proper tools and kits and experience, 3T is very easy to dissamble, why not search on YouTube there are many
    Btw When you press the button do you hear any click sound or feel the button is being pressed??
    You see that green rubber, well I was curious to see if it's easy to replace battery and trying to reassemble I might have damaged that green rubber or could be it already was near it's end, who knows I pressed power didn't work so I made a similar hard rubber with parts I had used Fevicol AllFix Multipurpose adhesive and got my power button working, they are cheap ₹300 to ₹600 full set of power, volume and alert slider, once OnePlus service center starts working I'll get officially replaced.
  8. Manideep peela
    Cupcake May 8, 2020
  9. SoniaB
    Community Hero 2020 May 8, 2020
    SoniaB , May 8, 2020 :
    Settings > buttons & gestures > quick gestures
    Select 3 finger screenshot
    BeingIncog and Manideep peela like this.
  10. Manideep peela
    Cupcake May 8, 2020
    SoniaB likes this.
  11. Manideep peela
    Cupcake May 27, 2020
  12. see_va_
    Eclair May 28, 2020
    see_va_ , via OnePlus 3 , May 28, 2020 :
    Connect the charging cable and press volume down button. Then you will be in the recovery mode select English language and click on exit then Reboot. Your phone will be restarted.
  13. Manideep peela
    Cupcake May 28, 2020
  14. Manideep peela
    Cupcake May 30, 2020
  15. Sidharth_9282
    Gingerbread Jun 1, 2020
    Sidharth_9282 , via OnePlus 3T , Jun 1, 2020 :
    connect your phone to computer..... open command prompt in computer then type the command adb devices(it will show the list of devices attached to computer) then adb reboot... phone will be rebooted
  16. N1590313074593
    Cupcake Jun 5, 2020
  17. N1590313074593
    Cupcake Jun 5, 2020
