power off problem
  1. pritshah710
    Donut Apr 3, 2017
    pritshah710 , Apr 3, 2017 :
    From last two days my op2 shutdown automatically and after shut it start automatically. What should I do?. Plz help
    Luke404 likes this.
  2. Arnavjmon5
    Froyo Apr 3, 2017
    pritshah710 likes this.
  3. jchang19
    Donut Apr 4, 2017
  4. pritshah710
    Donut Apr 4, 2017
  5. Arnavjmon5
    Froyo Apr 4, 2017
    Arnavjmon5 , Apr 4, 2017 :
    Did u try performing a hard reset. Else go into recovery by holding the volume down button and power button together while ur phone is switched off and reset all ur settings. It should work
  6. Arnavjmon5
    Froyo Apr 4, 2017
    But you will lose all ur apps and accounts. The only thing that will remain would be ur pictures, videos and songs I believe
  7. G_Chris_Murphy_ymNT
    Eclair Apr 4, 2017
    G_Chris_Murphy_ymNT , Apr 4, 2017 :
    try updateing or try downgrading, if that does not work check for device stability, if that does not work then factory reset, if that does not work contact one plus support for help
  8. pritshah710
    Donut Apr 5, 2017
    pritshah710 , Apr 5, 2017 :
    Thank you sir
  9. 281192
    Cupcake Apr 5, 2017
