Power on
  1. H1551388588962 Cupcake Jul 17, 2019
    H1551388588962, Jul 17, 2019 :
    I accidentally dropped my OP 6T McLaren and shattered the screen and back glass gave it for repair at OP service center and now when i try to turn it on it shows this screen.
    please anybody knows what this is has experienced it? and how do I fix it.
  2. B_Wrath Marshmallow Jul 17, 2019
    B_Wrath, Jul 17, 2019 :
    Did you ask the service center about this? What did they say?
  3. H1551388588962 Cupcake Jul 17, 2019
  4. B_Wrath Marshmallow Jul 17, 2019
    Then they should fix it if it was the case as soon as you received the phone from service center. Go there and ask them to fix it.
    Kytharsis and dm_ayodhya like this.
  5. H1551388588962 Cupcake Jul 17, 2019
    no I was at the center when the took it they swapped the display then when they try to turn it on this screen shows up
  6. Scherpenseel Jelly Bean Jul 17, 2019
    Scherpenseel, Jul 17, 2019 :
    Exactly what @B_Wrath is saying: Go back and let them fix it? They made a mistake with the battery. How should we on this forum be able to help you with a hardware issue?
  7. H1551388588962 Cupcake Jul 17, 2019
    they wanna change the entire mother board because they can't figure out what it is it's a McLaren edition and the mother board costs quite some money I don't want to spend that much thats why I am here.
    Starcommander likes this.
  8. Scherpenseel Jelly Bean Jul 17, 2019
    Well, I don't have a motherboard for the OP6 laying around here, so I can't do it any cheaper. You probably broke the motherboard along with the screen. Shit happens, don't drop your phone.
    Kytharsis likes this.
  9. H1551388588962 Cupcake Jul 17, 2019
    I know you don't have a spare motherboard lying around thats the reason why I didn't ask for one, this thread is to find out if anyone else has faced similar problem and what fixed it for them, that's what forums are for ain't that right? to discuss on an issue and find possible solutions for it.
  10. camohan Marshmallow Moderator Jul 17, 2019
    camohan, Jul 17, 2019 :
    This is hardware related issue and this can only be solved at service centre. That's what users are trying to explain you.
    This seems to be a rare case and not everyone faces it.
    When you got your device repaired, I am sure you would have turned in on to check. Did it at that time gave the same error?
  11. H1551388588962 Cupcake Jul 17, 2019
    brother I didn't get it fixed I took it to the center hoping it'll be all good again once I get the screen replaced, the officials at the center ran a test on the phone to see if it's good using a spare display they had lying around before taking the phone for service they informed me of the issue and said they don't exactly know what it is and that a motherboard swap is only thing they can suggest, so I took my phone back with me.
  12. Scherpenseel Jelly Bean Jul 17, 2019
    We understand your issue, don't need to keep explaining it. But I still don't see how users on a forum can support you on a hardware issue. We can't repair a broken motherboard.
    Kytharsis and Muhsin_Sultan like this.
  13. H1551388588962 Cupcake Jul 17, 2019
    I am trying to find someone who had a similar experience maybe his insight can help me I seriously don't expect any help from you so you don't really have to keep replying.
  14. ngydat KitKat Jul 17, 2019
    ngydat, Jul 17, 2019 :
    Unfortunately, you won't. This is the first time I read about this (I'm sure other users can say the same thing).
  15. hotsauce Lollipop Jul 17, 2019
    hotsauce, Jul 17, 2019 :
    Try open the phone up, take out battery then put battery back in. Instructions in video.
  16. H1551388588962 Cupcake Jul 17, 2019
    thank you man but it didn't help.
  17. Starcommander Jelly Bean Jul 17, 2019
    Starcommander, Jul 17, 2019 :
    I can totally understand what you are going through. Its very hard to believe that your very own phone fell and now misbehaving.
    What I feel is McLaren edition used special hardware for warp charge. May be that service centre didn't knew about its working. Try different service.
    As my fellow members @Scherpenseel @camohan said, we cannot help because the device which you are using is alone rare and the problem is more rarer. All I can say is Hard luck buddy
    Kytharsis and H1551388588962 like this.
  18. H1551388588962 Cupcake Jul 19, 2019
    H1551388588962, Jul 19, 2019 :
    hey I figured out what the issue is the guys at the center didn't have a McLaren edition battery and the regular 6t battery doesnt work. now the problem is they can't order a battery can anyone tell where can I buy a spare battery.
