Pre-applied screen protector Vs Tempered Glass screen protector Oneplus 5
  1. muhsoh
    Gingerbread Jul 24, 2017
    muhsoh , Jul 24, 2017 :
    Hi all. I have recently purchased Oneplus 5 after using OP2 and OP3T. OP5 came with pre-applied normal screen protector. I wanted to have views of OP5 users that the pre-applied screen protector is good enough or I should remove it and apply Tempered glass screen protector? Glass used for OP5 screen is Gorilla 5 so should I trust the glass material or it is good to apply tempered glass screen protector?
    Regards, Sohail
    MrMysakovich likes this.
  2. MrMysakovich
    Ice Cream Sandwich Jul 24, 2017
    MrMysakovich , Jul 24, 2017 :
    Hola,
    Today my OP5 arrived, I throw away pre-applied protector and put on it original 3D tempered glass.
    Customer support said me, that pre-applied protector is there only to keep display fresh..
    Do not trust anyone ... Buy glass ;)
  3. puneetkm17
    Eclair Jul 24, 2017
  4. Sven Erik Rebane
    Sven Erik Rebane , Jul 24, 2017 :
    Why do you waste money on a tempered glass, buy a silicon case and you will be done. It offers no protection outside of scratches
  5. Jayjay394
    Cupcake Jul 24, 2017
    Jayjay394 , Jul 24, 2017 :
    Leave the factory protector on for as long as possible then buy the most recommended replacement on retail sites. I immediately buy a silicone case AND neoprene wallet for hiking/cycling and a Stilgut wallet case for everyday.
  6. muhsoh
    Gingerbread Jul 25, 2017
    muhsoh , Jul 25, 2017 :
    Well this pre-applied screen protector is bit better then tempered glass protector which are currently available in UAE. So I am trying to get official 3D tempered glass from official Oneplus site.
  7. muhsoh
    True. Only Oneplus 2 tempered glass was covering complete screen and that was the best.
  8. muhsoh
    Thats what I am thinking to use the default protector till the time I get the official 3D Tempered glass protector either from USA or India.
  9. puneetkm17
    Eclair Jul 25, 2017
    puneetkm17 , Jul 25, 2017 :
    but by mistake I brought normal one haha
  10. muhsoh
    For Oneplus 5? I think on Oneplus official site, only tempered glass is available...
  11. puneetkm17
    Eclair Jul 25, 2017
