3
problem facing with pie
  1. F1528180347876
    Cupcake Sep 27, 2018
    F1528180347876 , Sep 27, 2018 :
    I'm OnePlus 6 user, the new update PIE is pretty good but the problem many of OnePlus 6 users facing is #BRIGHTNES before the pie my mob will take Max 30 to 40 percentage of brightness but now after updating to pie my mob is getting 70 to 80 percentage of brightness it is effecting battery percentage too.Anyone can't use the mobile with with that high brightness regularly. plz resolve this .
  2. Aks41179
    Jelly Bean Sep 27, 2018
  3. Catalin_Buzescu
    Catalin_Buzescu , Sep 27, 2018 :
    Just an user forum here mate. That means people like you and me. Nothing I can do for you.
    Maybe try contacting oneplus through official channels. Like the feedback section.
    Aldo, I don't have any problems with brightness affecting battery life
    Claudiu Cioloca and Aks41179 like this.
  4. Badr.D
    Gingerbread Sep 27, 2018
    Badr.D , Sep 27, 2018 :
    official channels? mind explaining to me cos im retarded when it comes to forums... is there a specific place where u can get help directly from a oneolus serviceman or so?
    F1528180347876 likes this.
  5. Adityatawade17
    Honeycomb Sep 27, 2018
    Adityatawade17 , Sep 27, 2018 :
    You may have encountered a situation when you use your phone at night and it’s difficult to control the brightness – it’s either too light or too dark. The problem is because that the brightness controller is too sensitive in the low luminance range. As a result, users may not like it when the brightness changes.
    Considering how are eyes are made, we decided to lower the sensitivity of the device in the low luminance range. After lowering the sensitivity, users can adjust the brightnessmore accurately and avoid discomfort.
    Badr.D likes this.
  6. F1528180347876
    Cupcake Sep 28, 2018
    F1528180347876 , Sep 28, 2018 :
    I'm not complaining about only one particular time or particular situation (nights). I experienced this in day time while I'm in my office & at home too.In my mobile brightness is always set to automatic brightness, before update with the same setting mob automatically set to 30 to 40 brightness at my cabin in office and that is very comfortable to me use mob.But now I mean after updating to PIE in the place mob automatically setting 70 to 80 brightness level ofcourse I can manually adjust it to 30 but at 30 level I can't use my mob with the same comfort.So, I'm forcing to use my mob at higher brightness level.plz resolve this @OnePlus.
    feeling disappointed.
  7. deangilvin
    Jelly Bean Sep 28, 2018
    deangilvin , Sep 28, 2018 :
    Try and follow, everyone here is a user just like you. There are no one plus employees on this side.
    Shut off adaptive brightness, manually move the slider, voila problem solved.
    If you want to complain any further complain to Google, they made the change.
    Kytharsis likes this.
  8. Catalin_Buzescu
    Catalin_Buzescu , Sep 28, 2018 :
    https://forums.oneplus.com/feedback.
    This could be one way of reporting.
    Also, if you want to contact a Oneplus employee directly, you can access their site, then go to the support section and then the Contact Us section.
    Badr.D likes this.
  9. anoopkeshavan
    Eclair Sep 28, 2018
