Problem finding which lockscreen control my lock screen
  1. vimobe
    Cupcake Jul 22, 2019
    vimobe , Jul 22, 2019 :
    I enjoy using my new OnePlus 7 and have been tweaking it by install few applications to enhance my user experience in using this device.
    Recently i have install and test multiple apps and launcher and uninstalled some as well.
    However im scratching my head trying to figure out which lockscreen controlling my current lockscreen, because i am quite sure the clock widget is not the standard oneplus clock and i have set the clock from oneplus setting to blank.
    attached is my lockscreen screenshot and my ambient display settings.
    Any suggestion to identify which lockscreen or apps controlling my existing lockscreen or clock?
    thank you
    edit- added list of apps
  2. ngydat
    KitKat Jul 22, 2019
    ngydat , Jul 22, 2019 :
    If you want us to help you identify what app is doing this, you might want to post the apps you have in your phone.
    vimobe likes this.
  3. vimobe
    Thank you so much for your reply. should i screenshot all the apps or any way that i can export the list of apps in txt format?
    seems like i cant copy paste the lost of app here..
  4. vimobe
  5. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Jul 22, 2019
    KeepTransisting , Jul 22, 2019 :
    That looks like the standard clock widget to me. You can't turn off or modify the lockscreen clock. You can only change how it looks on the ambient display.
    vimobe likes this.
  6. vimobe
    yes but i have disabled the standard clock widget. and yet the clock still showing.
    and the standard digital clock for oneplus 7 have a red color element. not plain white
  7. KeepTransisting
    Read closer what I said. You can not disable or change the clock on the lock screen. The setting your modifying is for the ambient display, not the lock screen.
    There is no red element or customization to the lock screen clock.
    vimobe and Logancd1 like this.
  8. vimobe
    only 1 digital clock in the standard built in lockscreen. and i set to blank
  9. Logancd1
    Ice Cream Sandwich Jul 22, 2019
    Logancd1 , Jul 22, 2019 :
    What @KeepTransisting said covers it. You changed settings for Ambient Display, not the lock screen. The lock screen can't be modified (in that way, at least - you can customize notifications and the background). That is definitely the default OnePlus clock widget for the lock screen. I'm staring at my own right now and it's identical.
    vimobe and KeepTransisting like this.
  10. KeepTransisting
  11. Logancd1
    This is the Ambient Display settings panel, not the lock screen settings.
    vimobe likes this.
  12. vimobe
    sorry for my misunderstanding of your reply.
    i understand what you mean now.
    anyway to disable the standard locksreen clock?
    ps: rooted my phone
  13. Logancd1
    No, the lock screen is locked the way it is. You can customize only the notifications and background, as far as I'm aware. You can perhaps customize the clock if you rooted and did some other stuff, but I don't see any point unless this really bothers you.
    vimobe likes this.
  14. KeepTransisting
    If you're rooted, there might be an Xposed module or something. XDA would be a better place to ask that question
  15. vimobe
    got it..
    meaning the third party apps will only help to change the ambient display look and feel but once in display finger required it will switch back to the original lockscreen?
    Sorry if im new with this because this is my first OnePlus and still relatively new with customization
  16. KeepTransisting
    Probably, yes. i can't confirm that completely as I haven't installed a lockscreen customization app in years.
    vimobe likes this.
  17. vimobe
    Noted. will browse around and find out more.
    thank you so much for enlighten me guys.. really appreciate it.
    cheers
    KeepTransisting likes this.
  18. sidharth.javvadi
    Gingerbread Jul 22, 2019
    sidharth.javvadi , Jul 22, 2019 :
    lol
    one plus gives the best software
    third party apps sucks sometimes
    people say Nova launcher
    I say one plus launcher for one plus
    vimobe likes this.
  19. vimobe
    yeah ive paid for hyperion and nova prime, and decided to keep the nova.
    the hyperion will ocassionaly give blank screen whenever i multitask between gaming mode to WhatsApp
  20. sidharth.javvadi
    I think they fixed the bugs for third party apps
    you should not be facing this issue now
    please report the bugs if your facing the issue even now
