21
Problem of app update and download in playstore
  1. Parthkansara
    Gingerbread Jun 20, 2021
  2. Princeshh1
    Gingerbread Jun 22, 2021
  3. Cicala
    Honeycomb Jun 23, 2021
    Cicala , via OnePlus 8 T-Mobile , Jun 23, 2021 :
    Best answer really is at the top! 🤓🤓🤓😇
    May ask if you're rebooting Daily? 🥇🤗 Found that best solution for a lot of issues, is too reboot. Yes, all kinds of support comes with your one plus Device's. Being such an inquisitive soul. Have read the manual for a few things. Up front it covers a few topics, that help with getting the best experience you can from your purchase. First rebooting Daily. One plus went the extra mile🤓🤗🥇😇 made it wicked easy to do so. By having the option to do it automatically you control when it powers down then power back up! 🤓🤗😇🥰
    Wanting to stick to the guidelines set for responding. Going to say hope that helps with a few things 🤓🤓
    J 🥇😇🤗🥰🤓🕯️🪄
  4. YSRReddy
    Cicala likes this.
  5. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jun 23, 2021
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Jun 23, 2021 :
    Before my update today I had around a week without reboots.
    If you need reboots or not kind of depends on the problem. I regular charge during the night and thus the maintenance jobs like dexopt-job will be done regularly and making sure the device keeps in good shape.
    I've experienced some issues linked to bubbles on both 8 Pro and 9 Pro. If you use that and have troubles I'd advice to test without it and see if your problems go away or not.
    I don't have my 8 Pro anymore so I can't replicate bubbles issues on it anymore.
    Cicala likes this.
  6. KulmeetSingh
    Eclair Jun 23, 2021
    Cicala likes this.
  7. Aditya Dutts
    Cupcake Jun 24, 2021
    Cicala likes this.
  8. YASH_SAVANT
    Cupcake Jun 25, 2021
  9. Cicala
    Honeycomb Jul 2, 2021
    Cicala , via OnePlus 8 T-Mobile , Jul 2, 2021 :
    🪄🪄🪄💯 percent This is a Solution!
    Positive vibes for Thoughts
    Never Settle
  10. Cicala
    Thank you, for this insight✨💕🕯️
    Swejuggalo likes this.
  11. Cicala
    Honeycomb Jul 3, 2021
  12. Cicala
    Honeycomb Jul 6, 2021
  13. Padhiyar Arunsinh
    Cupcake Jul 6, 2021
  14. Cicala
    Honeycomb Jul 9, 2021
    Cicala , via OnePlus 8 T-Mobile , Jul 9, 2021 :
    Still going through settings 😂😃😃😃😂 this chic will find a solution!
    Never Settling ❤️🕯️
  15. M1621577122117
    Cupcake Jul 12, 2021
  16. U1591764908351
    Cupcake Jul 21, 2021
  17. R_vindwalkar
    Froyo Jul 22, 2021
    R_vindwalkar , via OnePlus 8 , Jul 22, 2021 :
    Even I also faced same problem. Just factory reset your mobile and reboot it then problem will fixed and update your playstore app then try it..
