problem please help!!
  1. I1511888123365
    Cupcake May 3, 2018
  2. JamesBoulder
    Gingerbread May 3, 2018
  3. the_o2
    User of the Year 2018 May 3, 2018
    the_o2 , May 3, 2018 :
    Restating the phone helps many times, btw your Oxygen OS version.
  4. F_Vivek_Chavan_yTiG
    Donut May 3, 2018
    F_Vivek_Chavan_yTiG , May 3, 2018 :
    i am also facing same issue in OP5 from last couple of daya after updating the phone....
    when incoming call comes, that time phone screen is supposed to be ON.... But screen is OFF and only ringtone rings.
    I1511888123365 likes this.
  5. F_Vivek_Chavan_yTiG
    Donut May 3, 2018
    restarting doesn't works..... this is happening from last couple of days after the latest update..
  6. the_o2
    What is your Oxygen Os version bro, 5.1.1 have the solution for that.
  7. Hydra Bob
    Marshmallow May 3, 2018
    Hydra Bob , May 3, 2018 :
    Try clearing the cache and data of the dialer app or the system cache from recovery mode. Failing that file a bug report with OP.
    https://forums.oneplus.com/feedback
  8. John Nana
    John Nana , May 3, 2018 :
    Try contacting customer support for that. I think it's some bug in the update. They'll help you out. I contact thei customer support too sometimes.
  9. F_Vivek_Chavan_yTiG
    Donut May 3, 2018
  10. the_o2
    Ok just do these 2 things..
    First: Go to setting->storage and memory (scroll down)-> cached data(click and clear the cache).
    and then
    Second: Wipe the cache partition by following step.
    1. Turn the phone off(unplugg the charger if charging).
    2. Hold Power and Volume Down
    3. English (or pick any language that you want)
    4. Wipe data & cache
    5. Wipe cache
    6. Yes
    7. Reboot.
    If problem not solved by this report you bug as above suggested.
  11. I1511888123365
    Cupcake May 3, 2018
    I1511888123365 , May 3, 2018 :
    yeah same problem
  12. I1511888123365
    Cupcake May 3, 2018
    latest version..after the update..this problem begins
  13. I1511888123365
    Cupcake May 3, 2018
    owkey bro..thankew you
  14. the_o2
  15. G_Swapnil_Chitnis_NAIz
    Eclair May 3, 2018
  16. JatinArc
    Froyo May 3, 2018
  17. F_Vivek_Chavan_yTiG
    Donut May 3, 2018
    tried this.. but still issue persist.....!!
  18. the_o2
