Camera Problem shooting 4K with Filmic Pro
  1. Mat11
    Honeycomb May 20, 2019
    Mat11 , May 20, 2019 :
    Hi community,
    Im a bit lost with the recording problem Im facing. I am trying to shoot in 4k for quality purposes as Im building a portfolio to try to sell footage to stock agencies. At my current state of budget I can only shoot with my smartphone and try to clean image as much as possible. Usually recording goes smoothly in various light situations, but when a use a light directly to the sensor in a low light high contrast situation the image "breaks":
    1- https://ibb.co/wJ50JNr
    In this frame level of noise is acceptable. Below de elbow there is some but manageable
    2- https://ibb.co/HNgrHKj
    Few frames later the image "breaks". There are zones of the image that are completely unusuable.
    3- https://ibb.co/gm3WkST
    Another example
    Im using FilmicPro app with a Oneplus 3, which is fairly old (2016)
    I don't know if it's my PC, lack of codecs, the recording, the sensor. And Im not even sure what it is or how to look it up. I haven't found other facing a similar situation.
    Can someone help me?
  2. F_Omar_A._Castillo_Casta
    Eclair Jun 1, 2019
    F_Omar_A._Castillo_Casta , Jun 1, 2019 :
    Is not your fault or hardware issue, the problem is OnePlus is not providing the proper support on Camera2 API. Neither can you record video at 60 fps on filmic pro.
    This is an old topic and OP is not hearing us. I have the same issue and other restrictions using my OP6 with Filmic Pro.
  3. WellingtonVilela
    Cupcake Sep 18, 2019
    WellingtonVilela , Sep 18, 2019 :
    It is sad to know that a powerful oneplus 7 pro does not have compatibility with a perfect application. OnePlus needs to listen to its customers and release camera API, I bought oneplus 7 pro just to make a big project
    I'm disappointed
    bluefog likes this.
