Satish.sjc1 , via OnePlus 8 , Oct 11, 2020 : Updated to oxygen os11... Facing problem with AOD... How to resolve
Satish.sjc1 , via OnePlus 8 , Oct 11, 2020 : When I set to all day it simply doesn't show... When I double tap home screen opens...
NeosporumbIu , Oct 15, 2020 : [QUOTE = "Satish.sjc1, post: 22206340, member: 3044188"] Обновился до Oxygen os11 ... Проблема с AOD ... Как решить [/ QUOTE] Hi. I have the same problem.. Were you able to eliminate it?
ronakbarman , via OnePlus 8 Pro Ultramarine Blue , Oct 15, 2020 : Disable the on tap feature and raise up feature, since you are gonna use it all day anyways, then it'll work.
NeosporumbIu , Oct 16, 2020 : [QUOTE = "ronakbarman, post: 22234764, member: 897697"] Отключите функцию при нажатии и поднимите, так как вы все равно будете использовать ее весь день, тогда она будет работать. [/ QUOTE] It still doesn't work. When you turn on the AOD, it just turns on a black screen.
NeosporumbIu , via OnePlus 8 , Oct 16, 2020 : It still doesn't work. When you turn on the AOD, it just turns on a black screen.
ronakbarman , via OnePlus 8 Pro Ultramarine Blue , Oct 16, 2020 : Try a cache wipe from recovery, if that doesn't help either, then a factory reset.
NeosporumbIu , via OnePlus 8 , Oct 16, 2020 : I've tried it all and it doesn't help. I know that Oneplus 8 Pro works AOD. But it doesn't work on OP 8. I'm currently communicating with technical support, maybe they will help. Or wait for the new version of the update.
lambrosbarca77 , via OnePlus 8 , Nov 28, 2020 : I have the same problem! I have already sent my feedback and they said me that they are gonna fix it with an update! On the latest update (11.0.2.2) OnePlus didn't fix anything!!!
NeosporumbIu , via OnePlus 8 , Nov 29, 2020 : Hi, watch the video on the link, do you have the same? https://drive.google.com/file/d/11vA7noTfELlX1_NYEhaiK7GtAzpz_qZ8/view?usp=drivesdk
NeosporumbIu , via OnePlus 8 , Nov 29, 2020 : I was beginning to think that the problem was with the phone. I have already used all the methods, and changed the firmware, did a full reset and nothing helps..
NeosporumbIu , via OnePlus 8 , Nov 29, 2020 : If you suddenly manage to solve the problem, can you write me a personal message with the solution?
