problem with Andromeda app
  1. Rajatkumar29
    Honeycomb Jan 24, 2018
    Rajatkumar29 , Jan 24, 2018 :
    Using a OnePlus 5. I'm trying to open my PC Windows 10 desktop Andromeda on my computer, but each time I get to the initial screen that says
    Andromeda Start Script by [projekt.] development team
    This requires Andromeda and Substratum installed on the device
    Make sure the device is connected and ADB option enabled
    Please only have one device connected at a time to use this!
    Press any key to continue . . .
    And then, as soon as I press any key to continue, the Andromeda window simply vanishes and nothing happens. (My USB is connected to my phone, the USB is set to file transfer, and "USB debugging" is enabled. Substratum on my phone keeps saying the connection status is "Disconnected." Not sure what to do. Any thoughts?
  2. GopalB.
    Nougat Jan 24, 2018
    GopalB. , Jan 24, 2018 :
    have you purchased andromeda app???
  3. Rajatkumar29
  4. Rajatkumar29
  5. Dhruv Tarpara
    Gingerbread Jan 24, 2018
    Dhruv Tarpara , Jan 24, 2018 :
    use java module instead of script. it works better.
    and don't forget to reboot after applying overlayes or theme .
