3
Problem with Buds z
  1. bipuwam
    Gingerbread Feb 23, 2021
    bipuwam , Feb 23, 2021 :
    While listening from pc, buds suddenly stop. At first right buds get a start and left.
    Svendejongste, NaigamJ and Javeth8 like this.
  2. FFrollaniJr711
    Cupcake Feb 24, 2021
  3. DEEPAK_2000
    Cupcake Feb 28, 2021
    DEEPAK_2000 , via OnePlus 7T , Feb 28, 2021 :
    How is it a sensor problem? Can you elaborate coz I am facing the same issue.
  4. FFrollaniJr711
    FFrollaniJr711 , via OnePlus 8 Pro , Feb 28, 2021 :
    The sensor identifies that it's in ear and if not, it pauses. When you re-position, it resumes. I've heard of people also putting tape over the sensor holes so it thinks it's always in.
  5. NaigamJ
    Cupcake Mar 3, 2021
    NaigamJ , via OnePlus 8T , Mar 3, 2021 :
    I face the same issue but in my case I was in a MS teams call and I did not move. Buds just went silent for less than a second, then one of those started first and then the other. I was using those on Laptop (Win 10).
  6. vikasb23
    Donut Mar 5, 2021
    vikasb23 , Mar 5, 2021 :
    Can you tell me location of sensor I will also try tap on holes so I can listen music without it pause every 2-3 minutes.
  7. FFrollaniJr711
    Cupcake Mar 5, 2021
    FFrollaniJr711 , via OnePlus 8 Pro , Mar 5, 2021 :
    Near the base of the gel. The hole there is for the proximity sensor.
  8. vikasb23
    Donut Mar 6, 2021
    vikasb23 , Mar 6, 2021 :
    is this correct sensor location? I used tape on this location but still my audio pause.may be black tape will work?
  9. FFrollaniJr711
    Cupcake Mar 6, 2021
    FFrollaniJr711 , via OnePlus 8 Pro , Mar 6, 2021 :
    That is the location. I changed my gels so I get more in my ear. You can try electric tape, may be more suitable than scotch.
