Problem with Camera OnePlus 7 Pro via OnePlus 7 Pro
  1. firstov.serg
    Cupcake Aug 8, 2020
    firstov.serg , via OnePlus 7 Pro , Aug 8, 2020 :
    Good day dear support
    I have one problem with wide lens camera . I added photo.
    I check camera lens and don't see any dust on the lens.
    And don't know what is problem( please help
  2. billyli19
    Eclair Aug 8, 2020
    billyli19 , Aug 8, 2020 :
    This seems to be more a hardware problem. When did you start noticing it? Looks to be a small dust particle on your wide camera module itself.
  3. firstov.serg
    Cupcake Aug 8, 2020
    Dear friend, I see this problem one week again
    And it started with big dot.
    I checked wide lens(it's top lens) bit don't see any scratches,dusts ((
  4. billyli19
    Eclair Aug 8, 2020
    So you never had any issues with the wide angle lens before? Very strange. Can you please try clearing the storage and cache? After that perform a reboot and see if the problem still persist. Please let me know.
  5. firstov.serg
    Cupcake Aug 8, 2020
    No,before never had problems with wide lens
    I checked clearing of storage and cache,but don't help. Same problem...
    I will try check from another apps(f.e. google camera) but in other apps I cannot check wide lens...
  6. billyli19
    Eclair Aug 8, 2020
    The Google camera app (Gcam) supports the wide-angle lens. Can you please install it and test it out to see if you still have that dot? Here is a link where you can download the APK. https://www.celsoazevedo.com/files/android/p/gcam-oneplus-7-t-pro/
  7. firstov.serg
    Cupcake Aug 8, 2020
  8. billyli19
    Eclair Aug 8, 2020
    Is your phone rooted, seems like the only way to get the wide angle lens to work with GCam is using a Magisk module to enable "AUX" for mult lens selection. I think the best option is to contact Oneplus customer service.
  9. firstov.serg
    Cupcake Aug 8, 2020
    No, it's not rooted.
    Ok,i will try contact with support team.thank you very much!
  10. billyli19
    Eclair Aug 8, 2020
    Sorry I couldn't help you very much! Best of luck!
