problem with home screen
Thread Status:
Not open for further replies.
  1. markus9312
    Froyo Oct 30, 2014
    markus9312 , Oct 30, 2014 :
    Hey, so my home screen suddenly shows no text under the apps, just the icons.
    This might have happened as I turned on trebuchet, not sure. How do I disable trebuchet? :p
  2. B4kken
    Lollipop Oct 30, 2014
    B4kken , Oct 30, 2014 :
    What other launchers do you have? Go to settings homescreen and change it.
  3. llcooljerry
    Jelly Bean Oct 30, 2014
    llcooljerry , Oct 30, 2014 :
    Just press the menu capacitive button
    Drag and slide up the three dots.
    Change the icon labels option.
  4. markus9312
    Froyo Oct 30, 2014
    When I search for "home" in the search on settings, I find it, and then it says I only have trebuchet. That's the only settings I've found for my homescreen.
  5. markus9312
    Froyo Oct 30, 2014
    Did it, it was set too on, tried disabling it, restarting phone and enabling it, didn't help.
  6. markus9312
    Froyo Oct 30, 2014
    llcooljerry likes this.
  7. llcooljerry
    Are you using any other launchers?
  8. llcooljerry
    Glad to know :)
  9. B4kken
    Ahh my bad, thought you wanted to chose another launcher :p glad it worked out.
  10. dbanez25
    KitKat Oct 30, 2014
  11. Jevoly
    Marshmallow Oct 30, 2014
    sp99, TeamValor91 and finaldentiny like this.
  12. finaldentiny
    Community Veteran Oct 30, 2014
    finaldentiny , Oct 30, 2014 :
    Problem Solved.
    Thread Closed:)
    sp99, TeamValor91 and llcooljerry like this.
