Problem with Instagram. via OnePlus 7T Pro
  1. DmytroLaptiev
    Cupcake Nov 20, 2020
    DmytroLaptiev , via OnePlus 7T Pro , Nov 20, 2020 :
    Hi!
    I have a problem with Instagram.
    After updating on Instagram, the program does not work.
    I can not post a photo and post. Reinstalled the program and cell phone doesn't help!
    I need to your help!
    Dmytro Laptiev. Ukraine.
    Starcommander likes this.
  2. YRJ
    The Lab - OnePlus 7T Reviewer; Community Hero 2020 Nov 21, 2020
    YRJ , via OnePlus 7T , Nov 21, 2020 :
    It's probably an issue with the app. What you can try for the timebeing is install an old version from apkmirror and wait for the next update, which would hopefully be more stable.
    DmytroLaptiev and G_plusone like this.
  3. Starcommander
    OnePlus Accessory Tester Nov 21, 2020
    Starcommander , Nov 21, 2020 :
    This is the issue I faced for 2 days.
    My solution was:
    1. Uninstall Instagram completely.
    2. Clear playstore cache
    3. Login to playstore via a different Gmail account
    4. Install instagram
    Leaving Beta program doesn't help. This bug has affected all OnePlus OxygenOS from OOS10 to OOS11. Also after the steps, do not update the app for this point of time. You can update once the issue is fixed.
  4. DmytroLaptiev
    Cupcake Nov 21, 2020
  5. sufi09
    Gingerbread Nov 27, 2020
  6. DmytroLaptiev
    Cupcake Dec 3, 2020
    DmytroLaptiev , via OnePlus 7T Pro , Dec 3, 2020 :
    Hello!
    Today is a problem with Instagram all day! I can not enter! The system displays an error message, either close the program, or restart! Please help me fix the problem!One plus 7th pro t!
  7. YRJ
    The Lab - OnePlus 7T Reviewer; Community Hero 2020 Dec 3, 2020
    YRJ , Dec 3, 2020 :
    Have you tried clearing the app cache?
    And did you try the old method that worked?
  8. Gabbarsingh95
    Honeycomb Dec 3, 2020
    Gabbarsingh95 , via OnePlus 7T Pro , Dec 3, 2020 :
    Try to clear the cache of instagram.. and check that play store giving update of instagram. If it is then update it.. i think this will solve your problem..
  9. the_o2
    User of the Year 2018; Community Scholar 2020 Dec 3, 2020
    the_o2 , Dec 3, 2020 :
    If you are on beta version of the instagram switch back to stable version,
    Uninstall and reinstalling the app fixed this issue for many people furthermore as said Instagram always want to work only on iOS, they are having problems with Android from the very beginning.
    DmytroLaptiev likes this.
  10. #10
  11. #11
  12. #12
  13. #13
  14. #14
  15. AnitaMishra
    Froyo Dec 5, 2020
