problem with my OnePlus 6t
  1. Raiden17o Cupcake May 22, 2019
    Raiden17o, May 22, 2019 :
    hello today internet doesn't work in some apps, for now I only discovered in games apps such as clash Royale or ff brave enxius. I don't understand what's happening.
    other apps works good and they work good with WiFi but if a turn on data the they just stop working
    To be fair it works but insanely slow, even tho my data works perfectly
  2. Iulian R. Gingerbread May 22, 2019
    Iulian R., May 22, 2019 :
    Settings>Apps & notifications>See all apps
    Find your app and go under Data usage and check your settings. Only the first switch should be enabled.
  3. Raiden17o Cupcake May 22, 2019
    yes.. only the first one is checked I tried everything from turning off the mobile and deleting cache
  4. Iulian R. Gingerbread May 23, 2019
    Iulian R., May 23, 2019 :
    Then it seems really weird .. do you use any apps that manage your data/battery consumption?
