2
Problem with the proximity sensor. via OnePlus 7T Pro
  1. #1
    Fatih Aşkın and O1581159581732 like this.
  2. dikoscilator
    Honeycomb Sep 29, 2020
  3. B1590053045443 , via OnePlus 7T Pro , Oct 6, 2020 :
    unfortunately it did not help
  4. smmcsweeneyv
    Froyo Nov 24, 2020
  5. Tokolozi
    Most Original Avatar Nov 24, 2020
    Tokolozi , Nov 24, 2020 :
    Check using an app like sensor checker to see if the sensor detects something in from of it properly.
    Sometimes a case or screenprotector can interfere with the proximity sensor.
  6. O1581159581732
    Cupcake Nov 24, 2020
    B1590053045443 likes this.
  7. B1590053045443 , via OnePlus 7T Pro , Nov 24, 2020 :
    write to support one plus that you have the same problem, I am in the process of analyzing errors with them, I made an error log and sent them
  8. B1590053045443 , via OnePlus 7T Pro , Nov 24, 2020 :
  9. smmcsweeneyv
    Froyo Nov 27, 2020
    smmcsweeneyv , via OnePlus 7T , Nov 27, 2020 :
    Ya I thought about it and their end result always tends to be do a factory reset. But it's bs because it's been this way from the beginning.
  10. B1590053045443 , via OnePlus 7T Pro , Nov 27, 2020 :
    i did a system restore twice, the first time it helped for a week and the problem came back so in my opinion it's something with the system
    I wrote to the one plus support that others had problems with it, the One Plus support replied to me to write to these people to report the problem One Plus, the more of us, the sooner something will happen
    smmcsweeneyv likes this.
  11. Bittoo06
    Ice Cream Sandwich Nov 29, 2020
  12. #13
  13. B1590053045443 , via OnePlus 7T Pro , Nov 30, 2020 :
    I did so, it helped for a week, and the problem came back, suggesting a system problem
