Problem with Wifi - very simple and I suppose being Android related
  1. dam76
    Eclair Sep 27, 2016
    dam76 , Sep 27, 2016 :
    Hi guys,
    I have a One, but I think this problem could affect a wild range of devices, if not Android as a whole.
    I searched about this problem, but I could not find a solution and now I'm asking for your help.
    When Android cannot connect to a WiFi network, appears "connection error" in light gray under the name of the network, where usually appears "connected", and does not try to connect again.
    Is there a setting somewhere to tell Android to keep trying to connect?
    Usually when I arrive to my house, it detects Wifi when I'm still very far, does not succed to connect (obviously) and then does not try to connect again.
    If I click "connect" manually when I am at home, it connects in a second.
    What can I do?
  2. bobbybabaletskOS
    Honeycomb Sep 27, 2016
    bobbybabaletskOS , Sep 27, 2016 :
    I don't think there's a specific setting, but you can turn off/turn on WiFi and it should reconnect within a few seconds
  3. dam76
    Eclair Oct 6, 2016
    dam76 , Oct 6, 2016 :
    Yes it does, but the problem is annoying...
    I wonder why Android developers thought that if a connection to a wifi network fails, it is a good thing do not try to reconnect again...
    bobbybabaletskOS likes this.
