Probleme in screen
  1. A1510761675021
    Cupcake Nov 20, 2019
    A1510761675021 , Nov 20, 2019 :
    I have a probleme with my one plus 5 screen i notice some logos in that in pubg still apear their shadow even when i stop playing like " killed " or " alive " or "helmet logo " any solution ?
  2. Waveform Modifier
    Marshmallow Nov 20, 2019
    Waveform Modifier , Nov 20, 2019 :
    Congratulations. You successfully damage your screen beyond repair. Nothing can be done by the community.
  3. A1510761675021
    how i damage it ?
  4. YRJ
    The Lab - OnePlus 7T Reviewer; Community Hero 2020 Nov 20, 2019
    YRJ , Nov 20, 2019 :
    It is what we call Screen Burn In. When you play a game at high brightness with graphics that are static and on the screen at all times it tends to burn in to the display. Unfortunately, this cannot be fixed and if it bothers you much you have to replace the display. It is not covered under warranty
  5. Waveform Modifier
    Yes. By playing PUBG at high screen brightness at long periods of time. Again, congratulations.
  6. A1510761675021
    But my old phone i played in pubg too much time then now with one plus and nothing happend with it ?
  7. YRJ
    was that a LCD display?
  8. A1510761675021
    i am sorry i mean my old phone i played pubg too much time and nothing happend to the phone .. but now i don't play too much and this happend that make me confused
  9. Waveform Modifier
    Was your old phone have the same type of screen with your current phone? How can you compare orange with a kiwi?
  10. A1510761675021
    Bro im not a pro in this things so please can u tallk in good way .. that mean one plus screen not that good
  11. samikojo
    Froyo Nov 20, 2019
    samikojo , Nov 20, 2019 :
    All amoled displays have this weakness. Your old phone probably had a lcd display. That type of display is not as prone to screen burn ins as oled displays. You should lower your screen brightness and play shorter periods of time to prevent any further damage to the screen. Nothing else can be done except changing the display.
    Edit. Pretty much every new phone has an amoled display so whichever phone you buy next will have this same weakness.
  12. Waveform Modifier
    No. You damaged your screen by playing games at high brightness. There is nothing OnePlus can do about your personal choice to do so. Screen burn-in been happening to anything with a screen for years. It doesn't take a pro to understand that. You damaged your screen. That is all. Case closed.
  13. A1510761675021
    what u mean by brightness ?
  14. Waveform Modifier
  15. A1510761675021
    u mean when i play i must reduce brightness and the screennwill not burn
  16. Horsault
    Moderator Moderator Nov 20, 2019
    Horsault , Nov 20, 2019 :
    What they're trying to tell you is that PUBG is apparently an addictive game, but has static graphics which will be displayed not moving for hours.
    This is dangerous for AMOLED screens, as it was dangerous for old cathodic screens. High brightness will only hasten the process.
    If you remember well, on computers, people used to install screen savers to display moving images instead of static desktop. It's exactly the same today with AMOLED technology.
    Your only real solution is to get your screen replaced and stop using apps like this for hours.
    Mr_Cyrox likes this.
  17. Deactivated User
    Nov 21, 2019
