11
Problems after Oreo update
  1. Sohailpathan25
    Froyo Nov 23, 2017
    Sohailpathan25 , Nov 23, 2017 :
    I updated my 3T to Oreo. After that my phone is lagging a lot, Mobile data not working speaker volume has reduced drastically. Please fix this
  2. Vinaytrue6681
    Gingerbread Nov 23, 2017
    G_K._A._Mamun_oQej likes this.
  3. JAG65
    Eclair Nov 23, 2017
    JAG65 , Nov 23, 2017 :
    WHAT?
    Factory reset? U sure?
  4. Shazibwani_10
    Froyo Nov 23, 2017
    Shazibwani_10 , Nov 23, 2017 :
    Factory reset! seriously bro!! loosing all the stuff that we have in our phone! backups can sometimes be very frustrating! why need to update your phone if you have to factory reset it after that
    maddehaan, awcy4eva and SampadaJain like this.
  5. Vinaytrue6681
    Vinaytrue6681 , Nov 23, 2017 :
    bcz its not the inner version update. its completely a new android version. if u purchase a new phone, then how u save ur back up. new version of android comes after a LONG TIME. And i think we can ( should) do it. but still you dnt want to factory reset then dnt update the latest version. stuck on the old versions. CHOICE IS ALL YOURS...
    vmugutrao likes this.
  6. naveenhv
    Donut Nov 23, 2017
    naveenhv , Nov 23, 2017 :
    You are not alone. Even i am having volume issues. I cleared the cache and some volume issues are fixed. But bluetooth volume is still low.
  7. G_Sai_Raina_syku
    Jelly Bean Nov 23, 2017
    G_Sai_Raina_syku , Nov 23, 2017 :
    Bro updates don't work like that. Do you factory reset your laptop on updating ? It's just that the new update is not fully stable and probably fixes will come in the next update
    maddehaan, awcy4eva, JoeyBing and 4 others like this.
  8. SMIT222
    SMIT222 , Nov 23, 2017 :
    try to clear the cache via recovery.
    it will help you with lag for sure
    mananbshah likes this.
  9. jijo_jamez
    Cupcake Nov 23, 2017
  10. Sohailpathan25
    Froyo Nov 23, 2017
  11. thakurayush0497
  12. Sai Krishna Thorata
    Ice Cream Sandwich Nov 23, 2017
    Sai Krishna Thorata , Nov 23, 2017 :
    how to go to recovery mode after oreo update..? unable to do with volume down + power button..
  13. amrkarthik
    amrkarthik , Nov 23, 2017 :
    I had a lot of software issues on my OP3 but I moved on with that. After oreo update, my OP3 started to shut down often. And it won't start up sooner, I had to press and hold the power button for at least few times. Then again within 30 minutes, it'll be powered off automatically. I tried a factory reset and while setting up the phone it got powered off. Now it is completely dead, I can't even switch it on. Lack of quality software on the good hardware. Now how I'll get it repaired?
  14. Sohailpathan25
    Froyo Nov 23, 2017
    You r scaring me buddy
  15. G_Jefferson_Madriz_XSVd
    Froyo Nov 23, 2017
  16. Vinaytrue6681
    if our laptop is running slow and lagging, then what we do. we re insatll our window. same phone and os is lagging for some people and not lagging for others, then what it means. it means they dnt know the way how to use a smartphone, Here i am not saying that bugs are nor there. But if we step to other android version then it is recommended to factory reset. When i will receive 8.0, same day i will reset my phone even it will be running so well. Oh come on, its not a big deal.
  17. G_Sai_Raina_syku
    Oreo isn't that stable right now lots of people are facing battery issues including me and some issues with volume so it is buggy clearing cache memory could be a fix. No issues in factory resetting but it would be a long process due backing up first and then restoring and preferably updates should not make us do that because that is essentially causing inconvenience.
    No problems with your suggestion just saying updating the phone should not be like that and I agree that some people don't know how to use their phone.
    JoeyBing and Gokulkumar V like this.
  18. amrkarthik
    It's true. Now I'm trying to install Oxygen OS 4.5.1. Even that also not possible as I'm unable boot my phone into bootloader
  19. Shashistorm
    Eclair Nov 23, 2017
    SampadaJain and evilcorp like this.
  20. SMIT222
    go to developer options and then turn on advance reboot
    now long press power button and press reboot that will open other 3 options one of them is recovery
