11
Problems after Oreo update
  1. jasonarima
    Gingerbread Dec 1, 2017
    #81
  2. M1512108646583
    Cupcake Dec 1, 2017
    M1512108646583 , Dec 1, 2017 :
    ok let me try dis
    #82
  3. M1512108646583
    Cupcake Dec 1, 2017
    tried yet not working
    #83
  4. jasonarima
    #84
  5. Sohailpathan25
    Froyo Dec 1, 2017
    Sohailpathan25 , Dec 1, 2017 :
    They haven't and no one from 1plus replied on this it seems that they don't even care about 3t after the launch of 5 and 5t
    #85
  6. M1512108646583
    Cupcake Dec 1, 2017
    #86
  7. OnePlus3T_Pharaoh
    Cupcake Dec 1, 2017
    OnePlus3T_Pharaoh , Dec 1, 2017 :
    Screenshot_20171201-230053.jpg Screenshot_20171201-230048.jpg Screenshot_20171201-230053.jpg Screenshot_20171201-230048.jpg
    I can confirm that there is no more Oreo update notification on my Oneplus 3T (A3003) bought in France. They must have seen all the complaints/comments and decided to cancel it for the time being. For the best as far I'm concerned.
    #87
  8. nilay_bagadia
    Cupcake Dec 2, 2017
    nilay_bagadia , Dec 2, 2017 :
    Exactly!
    but any idea when the bug fixes would arrive?? i'm facing the same problems in addition to faster drainage of battery, apps are unresponsive sometimes to mobile data but responsive to wifi
    #88
  9. G_Sai_Raina_syku
    Jelly Bean Dec 2, 2017
    G_Sai_Raina_syku , Dec 2, 2017 :
    no idea when fixes will arrive but battery life is better now just let your phone settle to the update i.e 2-3 days or 4-5 charging discharging cycles and the battery life will be back to as it was on nougat or even better. I get 5:30-6 hours sot consistently. No idea about cellular data issue because mine works fine try to see in other threads about that I you can find about it.
    #89
    JoeyBing likes this.
  10. Abhishek Ghosh
    Donut Dec 2, 2017
    Abhishek Ghosh , Dec 2, 2017 :
    I don't think that I had to factory reset my phone after Nougat update... even after the INNER VERSION update, my phone was running absolutely smooth. but this update has some issues with it... that is why every 4 out of 5 user is facing problems.
    #90
  11. G_Sai_Raina_syku
    true factory reset isn't necessary and the bugs are there in this update.Some get fixed on their own(battery life) while other still persist(like lower volume) which will most probably be fixed with the next update.
    #91
  12. sandeep21
    Honeycomb Dec 2, 2017
    sandeep21 , Dec 2, 2017 :
    Yes, even i did factory data reset and now it's working flawlessly. Even SOT is increased
    #92
  13. Sohailpathan25
    Froyo Dec 2, 2017
    Sohailpathan25 , Dec 2, 2017 :
    Does the Oreo update notification dots if der r any unreaded notifications? If yes mine is not showing any
    #93
  14. HWAM
    HWAM , Dec 2, 2017 :
    It's about time they pulled the update. Using OnePlus 3 and OnePlus 3T owners as beta testers for their future 5T release, unbelievable. Even the beta Oreo was better. Come on OnePlus, your hardware is great but the software is far from perfect. Take a look at LineageOS and learn.
    #94
    Sohailpathan25 likes this.
  15. G_Jatin_Paul_Jqjk
    Cupcake Dec 2, 2017
    G_Jatin_Paul_Jqjk , Dec 2, 2017 :
    me too
    #95
  16. nekrosoft13
    Froyo Dec 2, 2017
    nekrosoft13 , Dec 2, 2017 :
    ONEPLUS Devs
    This is first Oneplus 3T update that bluetooth actually will connect to my car on first or second try, WHATEVER YOU DO, DON'T BREAK BLUETOOTH AGAIN!
    on nougat I had to click connect 10-15 times before it would connect, DON'T REVERT BACK!
    Oreo update works great!
    #96
  17. klaus-123
    Cupcake Dec 2, 2017
    klaus-123 , Dec 2, 2017 :
    Hello
    Just a short feedback: I updated my 3t 2 day ago amd everythin forks fine so far - reading all the issues I hope it will stay like that......
    Greetings from Germany
    Klaus
    #97
  18. mananbshah
    Cupcake Dec 2, 2017
    mananbshah , Dec 2, 2017 :
    I am having a peculiar issue... While listening to music (using Wynk) or watching a movie (primevideo), sometimes my audio switches from main speaker to telephonic speaker everytime there is a new notification. When I pause the music/video and replay it works fine again till there is a new notification... Any suggestions or ideas? It's been happening after the oreo update only...
    #98
  19. Kishan333
    Cupcake Dec 2, 2017
    Kishan333 , Dec 2, 2017 :
    I also updated to Oreo in my op3.
    After installation I faced :
    1. call speaker becomes low.
    2. terrible network speed
    some of the apps not able to use Wi-Fi due to some reasons even WiFi speed is very good and same thing happens when I am connected to cellular network.
    #99
  20. G_Alan_Mikic_CGxi
    Cupcake Dec 3, 2017
    G_Alan_Mikic_CGxi , Dec 3, 2017 :
    DATE PROBLEM SOLVED
    I used 1 sim,and after the upgrade to oreo data is lost or it worked for 2-3 minutes.
    For me, the solution is:
    1. Insert sim 2 with a data (leave your sim1 in slot sim 1)
    2. Select in sim 2 data settings (2,3,4G)-wait for the mobile to transfer the internet to sim2 !!
    3. If everything is set correctly (especially APN) data should work with sim 2.
    -in my case APN did not have to manually enter because it is on the sim card!
    4.Wi-Fi turn off and let your cell phone work on data for a few minutes. Surf or check if you really are doing the data.
    -Sometimes he writes 4G, and there is no internet.
    If there is still no data on the new sim, switch the internet to sim 2 on 1 and 1 to 2 again.
    It will work ....
    When you have an internet connection on any card, turn off your mobile phone, remove the SIM that you do not need and turn on the phone. The cell phone will see that a Sim in your cell phone will automatically work with the only sim in the phone.
    That's all.
