2
OxygenOS Problems after oxygen os 4.1.6 update
  1. Rithwii
    Donut Jun 25, 2017
    Rithwii , Jun 25, 2017 :
    After updating my 3T to oxygen os 4.1.6, I started experiencing several stutters and lags occasionally. I used to play GTA SA at maxed out settings earlier, but since the update, I started facing white screens in display and lags, which resulted in downgrading the settings to medium. Also, I feel a slight lag while opening WhatsApp and Facebook Messenger.
    So I kindly request the community to help me with the bugs above. any help will be deeply appreciated. Thanks.
    ZOOOlander55 and Sunil Halthore like this.
  2. phw990
    Froyo Jun 25, 2017
    Rithwii likes this.
  3. Rithwii
    Donut Jun 26, 2017
    Rithwii , Jun 26, 2017 :
    No. but I cleared all cache files...
  4. sharkyslo
    Gingerbread Jun 26, 2017
    sharkyslo , Jun 26, 2017 :
    Try to make a clean install (factory restore)...
  5. Jcouling
    Cupcake Jun 26, 2017
    Jcouling , Jun 26, 2017 :
    Has anyone noticed that they can't delete fingerprint records after updating to 4.1.6?
    My fingerprint scanner has become increasingly less likely to unlock my phone recently, so I've tried to delete and re-scan my fingerprints, but when I go to the Fingerprint list, tap the fingerprint I want to remove and re-scan, I'm prompted to enter my screen pattern (which I do) and the reset screen shows for a split second before returning to the Security & fingerprint page with the list of fingerprints.
    Is this a known bug, and any ideas how to get around it without wiping the phone?
  6. sharkyslo
    It is working on my OP3...
    Rithwii likes this.
  7. G_Ketan_Maniyar_NoLX
    Eclair Jun 26, 2017
  8. Rithwii
    Donut Jun 27, 2017
    Rithwii , Jun 27, 2017 :
    No problems so far in the fingerprint section...
  9. SiddyFCB27
    Cupcake Jun 27, 2017
  10. Neel_7158
    Donut Jun 27, 2017
    Neel_7158 , Jun 27, 2017 :
    I have been noticing screen rotation lag after the update, sometimes it doesn't even rotate
    Solaiman.Z.E and Rithwii like this.
  11. Rithwii
    Donut Jun 27, 2017
    update to nougat(oxygen os 4 .1.6) your google now will change automatically to google assistant.
  12. F_Marius_Dumitrescu_BhlD
  13. Rithwii
    Donut Jun 28, 2017
    Rithwii , Jun 28, 2017 :
    Some threads in community show that VOWifi is available in 4.1.6. Since I don't have a wifi connection, I can't confirm that.
  14. G_Pranjal_Parikh_ffRW
    Donut Jun 29, 2017
    G_Pranjal_Parikh_ffRW , Jun 29, 2017 :
    I am not able to update to 4.1.6 after I paused it at 71.3%.
    It's not getting downloaded on mobile data as well as wifi.
    Please help with the problem.
  15. Rithwii
    Donut Jun 30, 2017
    Rithwii , Jun 30, 2017 :
    I had the same problem too.. try after 2 or 3 days, it will start download from 71.3% itself.
  16. G_Pranjal_Parikh_ffRW
    Donut Jun 30, 2017
    G_Pranjal_Parikh_ffRW , Jun 30, 2017 :
    Ok.. Will wait for 2-3 days.
    Thanks mate!
    Rithwii likes this.
  17. sixgables
    Cupcake Jun 30, 2017
    sixgables , Jun 30, 2017 :
    I've had all sorts of weird screen issues after the update. Hoping it fixes soon...
    Solaiman.Z.E likes this.
  18. Rithwii
    Donut Jul 1, 2017
    Rithwii , Jul 1, 2017 :
    yeah me too... I see a mild lag overall after the update... But still leagues faster than the phones that my friends use...
  19. mickyreayman
    Cupcake Jul 1, 2017
    mickyreayman , Jul 1, 2017 :
  20. mickyreayman
    Cupcake Jul 1, 2017
    My oneplus 3 apps screen keeping flickering, it's weird. Has anyone found a fix for this?
