Problems bugs and improvements needed
  1. dhawal.d7 Gingerbread Jun 9, 2019
    dhawal.d7, Jun 9, 2019 :
    Device: Oneplus 7pro
    1 heating while charging
    2 heating while normal use
    3 popup camera pops everytime a video call is received no matter where the phone is. When in pocket and if the power button is pressed it pops up. A pocket mode is needed at the earliest
    4 battery life not upto mark. Getting just 4.5 hours of screen ontime.
    5 camera needs a loads of fixes. Telephoto and widelens become too noisy in low light. Nightscape pictures are green dominated. Focus not accurate.
    6 double tap and ambient display still not working perfectly. None of them works in dark
    7 call quality average
    8 warp charging is pretty slow and works opposite to its name. Takes 75 minutes to go from 20 to 100
    9 Fingerprint sensor misses out 1 in 3 times. Still not accurate completely.
    10 stereo speakers are good but still not great and need some tweaks.
    11 Ram management not good. Anytime i check it just 3 or 3.5 gb is free out of 8gb with no apps running
    12 cannot scroll down the notification panel while on a call. Tried alot of times but the issue is permanent
    chirag2056127 likes this.
  2. Matt 80 Lollipop Jun 9, 2019
    malidan and Nick 59 like this.
  3. malidan Marshmallow Jun 9, 2019
    malidan, Jun 9, 2019 :
    Have you done the latest update? Because half of the stuff you have list this staff member reckons they have fixed them.
    https://forums.oneplus.com/threads/known-issues-for-oneplus-7-pro.1044076/#post-20359761
    I know that's not proof of anything seen as ghost touches are still being reported and that's supposed to be fixed too.:oops:
    Matt 80 likes this.
  4. dhawal.d7 Gingerbread Jun 9, 2019
    malidan likes this.
  5. malidan Marshmallow Jun 9, 2019
    Wow then your next step is a factory reset, I know data,data,data but it's got to be done. Back up what you must keep and do the deed, if it's still the same after that you have a decision to make.
    .Replacement
    .Refund
    Let us know know how you get on.:)
  6. dhawal.d7 Gingerbread Jun 9, 2019
    Let's try this out as well. I'll surely let you know what happens next.
    malidan likes this.
