3
Problems facing on one plus 7t
  1. G_Atharva_Petkar_qGVL
    Cupcake Oct 6, 2019
    G_Atharva_Petkar_qGVL , Oct 6, 2019 :
    I recently bought the phone..N I was damn happy to be a one plus user since day 1 n now again.!!the problem im facing is that one plus had put forth the message sorting UI that helps to sort all the OTP messages n Transaction messages n Contact messages to sort separately as different folder..but i couldnt find that at all..instead all OTP's and other messages like adds n payments are displayed under one folder named as NOTIFICATIONS..why is this so..??im not able to see the network speed in status bar too..when im connected over wifi..im able to see the network speed only when im connected through mobile data!..these made me disappointed!plzz help me..get me the update or suggest some solutions to it!!
    Thanks!
    One plus 7T user
  2. Risalat00
    Cupcake Oct 7, 2019
    Risalat00 , Oct 7, 2019 :
    sir i am from India and here call recording is legal.
    but i dont know where call recording is saved on oneplus 7t.
    i am just seeing a message that call is recorder, but where..
    plz help,.
  3. Photoman9988
    KitKat Oct 7, 2019
  4. thegame1109
    Eclair Oct 8, 2019
    thegame1109 , Oct 8, 2019 :
    This user is a spam...He keeps on interrupting other user problems and making useless comments. Please ignore this user.
  5. kishArrow , via OnePlus 7T Glacier Blue , Oct 8, 2019 :
    u will find the recorded call in the recorder app provided by oneplus pls check in that
  6. #6
  7. Q1570735169219
    Cupcake Oct 12, 2019
    Q1570735169219 , Oct 12, 2019 :
    I am facing problems on one plus 7t like with ambient display... I have turned the settings on still when i pick up or tap on the display it does not come all the time... I sometimes have to turn on and off to solve the problem.... Pls fix all these problems one plus team
  8. Aditya.kuwar
  9. I1571072922726
    Donut Oct 14, 2019
  10. Probowl2
    Donut Oct 18, 2019
    Probowl2 , Oct 18, 2019 :
    The one plus 7T phone is not compatible with Verizon. I picked one up at the 7T pop up store last Friday and still can’t get it to work with Verizon.
  11. Tenista
    Cupcake Oct 18, 2019
    Tenista , Oct 18, 2019 :
    you should check with Verizon as:
    This carrier only accepts approved devices on its network.
    Even if a device supports some or all of the required frequencies for this carrier, it will not be able to connect unless the device is approved for this network. Check with the network operator to confirm whether a device is approved or not.
    hope this helps
  12. Probowl2
    Donut Oct 18, 2019
    when i bought the device at the NYC pop up store last friday, i made a specific note asking the workers there if it works on verizon and they told me yes it does.
  13. W1570853425468
    Cupcake Oct 19, 2019
    W1570853425468 , Oct 19, 2019 :
    no-one can help me to replace only back side of phone it's looks odd nd wrong impact to OnePlus audience if they asked to me nd I tell it's drowback back side is not strong plzz help nd support me
