24
Problems in OnePlus 6T
  1. Gaurav Panghal Froyo Nov 5, 2018
    Gaurav Panghal, Nov 5, 2018 :
    Heating Problem:-
    After playing game on the device the back panel is showing heating effect and you can feel it through the back cover itself.
    Battery Drainage:-
    Battery is draining very fast as compared to OnePlus 6 although it has bigger but i think the battery of OnePlus 6 is long lasting then 6T.
    App Auto Shutdown:-
    If i have something on download the app is closing if i turn of the screen and app is in background.
    Playstore:-
    Sometimes the app won't download over mobile network while other app work fine.
    Well i am a die-hard fan of OnePlus and after seeing these fault it a bad sign for OnePlus reputation.
  2. samprocat Ice Cream Sandwich Nov 5, 2018
  3. Gaurav Panghal Froyo Nov 5, 2018
  4. samprocat Ice Cream Sandwich Nov 5, 2018
  5. Gaurav Panghal Froyo Nov 5, 2018
    G_Mayur_Kale_IDgo and Desejmon like this.
  6. H1541010681240 Cupcake Nov 6, 2018
    H1541010681240, Nov 6, 2018 :
    most of the times the app is not downloading over mobile network but other apps work fine
    plzz solve me this issue
  7. risky1301 KitKat Nov 6, 2018
    risky1301, Nov 6, 2018 :
    You do realize that PUBG is going to drain your battery extremely fast. That is a big file game with alot of graphics. I play Racing Rivals and it does drain a bit fast, PUBG will drain it much faster than my racing game!
  8. Gaurav Panghal Froyo Nov 6, 2018
    Gaurav Panghal, Nov 6, 2018 :
    yes bro in many apps like in pubg the downloading stop aroud 1 gb.
    H1541010681240 likes this.
  9. H1541010681240 Cupcake Nov 6, 2018
  10. Gaurav Panghal Froyo Nov 6, 2018
    apart from pubg also bro like yesterday my friend and i are using same game and i was watching videos offline while my friend was watching them online and the battery of oneplus 6 down from 100 to 90% while mine get from 80 to 62% in 6T.
  11. Praks92 Eclair Nov 6, 2018
    Praks92, Nov 6, 2018 :
    Is your Pubg game fitting in the screen completely? or its cutting the game content from the corners?
  12. Gaurav Panghal Froyo Nov 6, 2018
    yup its cutting the information from corners as its in fullscreen mode
  13. Praks92 Eclair Nov 6, 2018
  14. Gaurav Panghal Froyo Nov 6, 2018
  15. Praks92 Eclair Nov 6, 2018
    ya but i saw on youtube about gaming video of oneplus 6t, in that the game is completely fitting in the screen.
  16. Gaurav Panghal Froyo Nov 6, 2018
    i will try to look at that and will inform you.
  17. Praks92 Eclair Nov 6, 2018
  18. Gaurav Panghal Froyo Nov 6, 2018
    remove the app from full-screen mode and the run after the there will be a very little information that is cut through the corner on right as it is due to the bezel less display
  19. samprocat Ice Cream Sandwich Nov 6, 2018
    samprocat, Nov 6, 2018 :
    App that you are having a problem is CPU and GPU intense app....
    There is no work around there.
    This app is more for Tablet or Laptop use.
  20. Vishwa Priya Cupcake Nov 6, 2018
    Vishwa Priya, Nov 6, 2018 :
    but 6 has good capacity than 6t
