24
Problems in OnePlus 6T
  1. Gaurav Panghal Froyo Nov 8, 2018
    Gaurav Panghal, Nov 8, 2018 :
    If you are travelling then your mobile network can't be stable i.e if we don't want any heating effect then we have to use wifi or should be in a place where network is stable?
  2. parthvarasani Eclair Nov 8, 2018
  3. C1541296434574 Cupcake Nov 8, 2018
    C1541296434574, Nov 8, 2018 :
    Hi Team,
    I didn't get official 3 cases and type c headphones for my preordered OnePlus 6T. how do I get these accessories?
  4. 78669 Donut Nov 8, 2018
    78669, Nov 8, 2018 :
    just buy them from amazon or oneplus.in they are not included with 6t.
  5. Gaurav Panghal Froyo Nov 8, 2018
    if you pre booked it on amazon you will get type c earphone on 15 nov.
  6. 78669 Donut Nov 9, 2018
    78669, Nov 9, 2018 :
    I want a trmporary solution to this
    yesterday I reset my phone but same problem occur again
    so when the download paused I switch the data card and it again resumed.
    I switched from jio to airtel when it paused and then it downloaded without more pause.
    I tried it with 2-3big apps.
    try this if you have internet in both of your sim.
    maybe it is causing due to slow internet in jio.
    try this once.
  7. Praks92 Eclair Nov 9, 2018
    Praks92, Nov 9, 2018 :
    same here, oneplus team has no solution of this issue
  8. Reynadess Eclair Nov 9, 2018
    Reynadess, Nov 9, 2018 :
    It depends on your graphics settings on PUBG. If everything is set to high and ultra it cost more processing power. Hence, more battery!
  9. Srikarnani Cupcake Nov 9, 2018
    Srikarnani, Nov 9, 2018 :
    I'm having Bluetooth issues. sometimes Bluetooth earphones are unable to switch to call when they are on music. any one with same problem?
    Selva_Senthil likes this.
  10. Gaurav Panghal Froyo Nov 9, 2018
    Gaurav Panghal, Nov 9, 2018 :
    not only battery but the device heat like hell near camera like you were not able to hold it anymore.
    Reynadess likes this.
  11. Gaurav Panghal Froyo Nov 9, 2018
    Srikarnani
    I'm having Bluetooth issues. sometimes Bluetooth earphones are unable to switch to call when they are on music. any one with same problem?​
    not a issue with oneplus bullet earphone
  12. Reynadess Eclair Nov 9, 2018
    I would suggest reset everything!
    These are my usage, and Screen on time!
  13. O1541738737883 Cupcake Nov 9, 2018
    O1541738737883, Nov 9, 2018 :
    when I play garena freefire . I am facing network problem within game even I have good network connection that time. after reinstalling game will run smoothly but only for short period of time.
  14. Aramaan Jain Gingerbread Nov 9, 2018
    Aramaan Jain, Nov 9, 2018 :
    Amazon doesn't have return policy I think so.
  15. 78669 Donut Nov 9, 2018
    it has I already checked that [e]1f601[/e]
  16. Aramaan Jain Gingerbread Nov 9, 2018
    Connect to a WiFi and then let it update apps.
  17. 78669 Donut Nov 9, 2018
    you think i didnt tried that ??
    i tried everything.
    its just a bug its not updating not going anywhere.
  18. Aramaan Jain Gingerbread Nov 9, 2018
  19. Aramaan Jain Gingerbread Nov 9, 2018
    I am facing the same issue. When I told this to the service center guy, he told me that the wiring in my house has some problem. Like how can you relate things like this.
    Jayesh Poddar likes this.
  20. U1541739571213 Cupcake Nov 9, 2018
    U1541739571213, Nov 9, 2018 :
    when I am on Google and I am scrolling it will just stop scrolling even if I scrolling hard it will just stop as soon as I lift my finger off the screen. This only happens if I am on Google for a while but then it will go away in about a minute.
