2
PROBLEMS REGARDING PIE UPDATE
  1. Vishav_deep Eclair Jun 14, 2019
    Vishav_deep, Jun 14, 2019 :
    After updating the device(3T) following problems occur
    - Camera issue : too much blur in taking the picture. Even on standby the camera shakes a lot. Very bad camera quality.
    - Automatic brightness is not responding well.
    - Device hangs a lot.
    - Battery life get worse.
    - Over heating of device.
    - Switching form recent apps is not so smooth.
    - Overall performance of device in Apps and games got even worse. The touch response was smooth in Oreo but after pie update it lacks a lot.
    Fix these bugs.
    O1539785310152 and G_M_MUch like this.
  2. R1550813188674 Cupcake Jun 14, 2019
  3. Vishav_deep Eclair Jun 14, 2019
  4. R1550813188674 Cupcake Jun 14, 2019
    R1550813188674, Jun 14, 2019 :
    bro i heard that it well get a few days to get stabilised with pie.. how much days had passed after updating ?!..
  5. Vishav_deep Eclair Jun 14, 2019
  6. R1550813188674 Cupcake Jun 14, 2019
  7. Vishav_deep Eclair Jun 14, 2019
  8. G_Ifeanyi_Achobandu_Gipz Cupcake Jun 14, 2019
  9. R1550813188674 Cupcake Jun 14, 2019
    Vishav_deep likes this.
  10. Vishav_deep Eclair Jun 14, 2019
    try playing some games and do multiple tasking.
  11. R1550813188674 Cupcake Jun 14, 2019
  12. Vishav_deep Eclair Jun 14, 2019
    yup the perfect update
  13. R1550813188674 Cupcake Jun 14, 2019
    bro can u measure your battery performance using accubattery and post.. mine is bad at 4hrs screen on time... on 8.0 !!dont know abt pie..
  14. SwissArmyBob Froyo Jun 14, 2019
  15. O1560539033102 Cupcake Jun 14, 2019
    O1560539033102, Jun 14, 2019 :
    There is an issue with the alert slider too. Can someone help? Every time the slider is toggled, screen goes blank and directly moves to lock screen after showing system error notification.
  16. frostywolfy Gingerbread Jun 14, 2019
    frostywolfy, Jun 14, 2019 :
    Do factory reset and most of your problems should go away. I do that most of the time for major update.
  17. czokoxxx Cupcake Jun 14, 2019
    czokoxxx, Jun 14, 2019 :
    hi. i have so much different issue here. i received notification about 9.0.3 update, so i downloaded. when try to update device was rebooting as normal but nothing happened. got info "installation failed please reboot" .tried for several times no result. downloaded manualy 9.0.3 ,9.0.2 and try to install from ZIP. still nothing for both versions. cleared cache ,wiped data...nothing helped. Now i receiving notification about update when try to download i got msg like "verification failed" or something similar and nothing happened after. no root ,bootloader unlocked but i updated OTA so many times before without any problem. anyone know ,anyone how to fix that? i would thankful for help.
  18. G_Алексей_Ген Eclair Jun 14, 2019
  19. Vishav_deep Eclair Jun 14, 2019
    Well i hope so but that not seem so fast. Moreover gaming after this update is like hell. Pubg lags like crazy feels like playing on a low end device
  20. Vishav_deep Eclair Jun 14, 2019
    well i also factory reset and these problems are there. Have you tried playing pubg? or any other games.?
