2
PROBLEMS REGARDING PIE UPDATE
  1. SwissArmyBob Froyo Jun 14, 2019
  2. Vishav_deep Eclair Jun 14, 2019
    Vishav_deep, Jun 14, 2019 :
    True , worst update ever by one plus
    SwissArmyBob likes this.
  3. G_Yuriy_Podoba_UHBx Cupcake Jun 14, 2019
  4. G_Алексей_Ген Eclair Jun 14, 2019
    G_Алексей_Ген, Jun 14, 2019 :
    Vishav_deep
    well i also factory reset and these problems are there. Have you tried playing pubg? or any other games.?
    The phone was laggy, animations were also not smooth, apps didn't work well before the factory reset, in my case, it solved everything, its a pity, if it is not work for you. No, i don't have time for playing games now, as i remember pubg have always had problems with our processor, maybe you should also try using gaming mode, i think it will help a little bit.
  5. Vishav_deep Eclair Jun 14, 2019
    Nope pubg on Oreo was quite smooth i have never experienced any issue with pubg on Oreo but this update got it worse and app starting and smoothness of the device is nowhere to be found.
  6. G_Алексей_Ген Eclair Jun 14, 2019
    When i was playing pubg on oreo there were problems) Unfortunately, i can't suggest something more useful than factory reset(
    Maybe try to wipe cache one more time and reinstall the game.
  7. Vishav_deep Eclair Jun 14, 2019
    Already done this nothing helps. Hopefully one plus is listening and will bring out some bug fixes and performance improvement update.
  8. P1560539073621 Cupcake Jun 14, 2019
  9. G_Mirza_Beg_rHBA Cupcake Jun 14, 2019
    G_Mirza_Beg_rHBA, Jun 14, 2019 :
    Bro wait for few more days. Then give another factory reset and check the OS performance. Since the issue has generated all over the globe, I'm sure OP will soon come up with a patch if not a small update later this month.
  10. Bouncer71 Lollipop Jun 14, 2019
    Bouncer71, Jun 14, 2019 :
    No issue on this side of the globe...
    Got the pie update today...
    Additional reboot after full installation and everything runs just fine...
    But I don't play any games like Pubg...
    The phone is just my workhorse... ;)
  11. sowmiknayak Cupcake Jun 15, 2019
    sowmiknayak, Jun 15, 2019 :
    I am having one plus 3 and after this update my phone has gone terribly slow and i am facing touchscreen problems as of now. Will keep posted for more issues. One plus team please fix these issues ASAP. We know you also are trying hard to analyze these and fix them but as a user its very difficult to use the phone as the issues irritates a lot.
  12. Vishav_deep Eclair Jun 15, 2019
    Vishav_deep, Jun 15, 2019 :
    true its getting frustrating that a device with that much power and specs hangs a lot.
  13. H1541358115405 Cupcake Jun 15, 2019
  14. R1560625022311 Cupcake Jun 15, 2019
    R1560625022311, Jun 15, 2019 :
    since last update for Android 9, I cannot connect my device to my PC.... No notification and no choice in the settings displayed for usb
  15. Vishav_deep Eclair Jun 15, 2019
    nope its awful..
  16. Vishav_deep Eclair Jun 15, 2019
    All i found in the threads that factory reset your device and all of your problems will b solved. You should also try this maybe it will help you.
  17. F_Brian_G._Wermeyer_Pgrw Cupcake Jun 15, 2019
    F_Brian_G._Wermeyer_Pgrw, Jun 15, 2019 :
    I updated yesterday. It's the biggest mistake. I really hate what they have changed. I want my old version of Oxygen back, please.
    This update has really ruined my "experience"/
  18. Kaito_kid Honeycomb Jun 15, 2019
    Kaito_kid, Jun 15, 2019 :
    4 hours is a bad sot ? like really ? do you have any knowledge about what you just said
    #38
  19. Kaito_kid Honeycomb Jun 15, 2019
    this is not even an accurate measurement as I don't think this is what you got in a single full charge
    #39
  20. P1560633876147 Cupcake Jun 15, 2019
    P1560633876147, Jun 15, 2019 :
    3T updated to 9.0.3 two days ago. Most noticeable problem is that Pie broke Signal Privacy Messenger app. Cannot launch application, cannot intiate outbound text or video. Signal was rock solid with Oreo. This is an unexpected step backward.
    #40
    C1560656463742 likes this.
