problems with alert slider via OnePlus Nord
  1. C1596791904588
    Cupcake May 9, 2021
  2. Aaron2017
    KitKat May 9, 2021
    Aaron2017 , May 9, 2021 :
    Try cleaning it out with a wooden toothpick or non metallic object, it might not be visible but there could be some dirt, or something like that, that has build up over time
    Shailender Sharma likes this.
  3. C1596791904588
    Cupcake May 9, 2021
    C1596791904588 , via OnePlus Nord , May 9, 2021 :
    Whenever I slide it to silent it's automatically turns to "ring".
  4. Shailender Sharma
    Marshmallow May 10, 2021
    C1596791904588 and Aaron2017 like this.
  5. Dresa91
    User of the Year 2016; Most Active User 2020 May 10, 2021
    Dresa91 , May 10, 2021 :
    Did you try to slide it in Safe mode?
    What is the result?
  6. C1596791904588
    Cupcake May 10, 2021
  7. Dresa91
    https://www.hardreset.info/devices/oneplus/oneplus-nord/safe-mode/
    Safe mode allows you to turn on the device with third-party apps disabled. Then you can easily uninstall apps that may be causing a conflict or software problem.
    Still facing issue: try to reset your phone.
    After reset still issue: contact support -> could be a hw thing
    C1596791904588 likes this.
  8. C1596791904588
    C1596791904588 , via OnePlus Nord , May 10, 2021 :
    Yes I tried the restarting the phone but it stays the same so I just dropped an mail on customer support . Anything else you can help me with? Any other scenario which leads to this problem.
  9. Dresa91
    Did you reset your phone and try it again?
  10. C1596791904588
  11. Dresa91
    RESET….
    same here:
    If I had meant restart, I would have written restart
  12. Young_Blood
    KitKat May 10, 2021
