Problems with bluetooth calls OnePlus CE 5G via OnePlus 9 Pro
  1. O1583076170989
    Cupcake Dec 1, 2021
    O1583076170989 , via OnePlus 9 Pro , Dec 1, 2021 :
    Hi. I keep having problems with bluetooth calls. When I'm in the car and I want to call someone it works fine. But when there is an incoming call, the sound on the bluetooth stops working and it goes to the mobile. I am very disappointed with this phone. I always hear that OnePlus phone are the best. But I'm having a horrible experience with this issue. Fix it as soon as possible
  2. Caomhin
    9 Series Expert, Participator of the Year Community Expert Dec 3, 2021
    Caomhin , via OnePlus 9 Pro , Dec 3, 2021 :
    Do you have the Alibaba app installed on the phone by any chance. There is an issue with this app and Bluetooth in different scenarios. If you do, uninstall the Alibaba app, restart the phone and see if that helps.
  3. O1583076170989
    Cupcake Dec 3, 2021
    O1583076170989 , via OnePlus 9 Pro , Dec 3, 2021 :
    No I don't have that app instaled. If you know another situation that can cause this problem tell me. I would be grateful
  4. Caomhin
    You could try the following to reset you Bluetooth adapter. Reset your Network adapters, see if that helps.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    This may also help.
    Disable "Sleep Standby Optimisation " in the
    Settings, Battery, Battery Optimisation, 3 dots menu top right, Sleep standby optimisation.
    Re-start your device.
    How to Fix Bluetooth Pairing Problems
    https://www.techlicious.com/how-to/how-to-fix-bluetooth-pairing-problems/comments-/CP8/
  5. O1583076170989
    Cupcake Dec 3, 2021
    Okay. Thanks. I will try it. If I can't fix it, I'll tell you
    Caomhin likes this.
