OxygenOS Problems with Oxygen os 11
  1. kotalkar
    Donut Apr 21, 2021
    kotalkar , Apr 21, 2021 :
    Hi. I have OnePlus 7 pro and I recieved Android 11 version with Oxygen OS 11. Design is great, but using phone now is not quick anymore. I found out that its so laggy, it feels even less than 60 hz ( not 90 as it should be). Also, gallery is not working good.
    Does somebody know when will the update come to fix this? Also, updates for 7 pro end on 14th May, so...
    Sakib4 likes this.
  2. Artemus.
    Community Hero 2020 Apr 21, 2021
    Artemus. , Apr 21, 2021 :
    Who said updates end on May 14th? It's got a whole 'nother year or two of support, my dude.
    As for the lag issues, back up your stuff, move it to Google Drive or your PC, format it, set it up without restoring, restore afterwards.
    flither, the_o2, Aaron2017 and 2 others like this.
  3. kotalkar
    Donut Apr 22, 2021
    kotalkar , Apr 22, 2021 :
    Because 7 pro was released on 14 May 2019 and it was said to be 2 years of updates. And now for 8 and 9 series i think 3 years. Anyways, its not possible to recieve more than 2 more years as of now.
    Also, dont have any interest in backing up data as it takes to much time. Also, its company`s duty to make it work.
  4. Artemus.
    Community Hero 2020 Apr 22, 2021
    Artemus. , Apr 22, 2021 :
    All phones get 3 years of updates, my dude. 2 years of feature updates and a year of security updates.
    As for the second part, it's not up to them, it's up to you to maintain your phone.
    Aaron2017 likes this.
  5. Sakib4
    Cupcake Apr 22, 2021
    kotalkar likes this.
  6. kotalkar
    Donut Apr 22, 2021
    Yes but as fixing a bug is not a security update, i probably wont recieve the fix
  7. kotalkar
    Donut Apr 22, 2021
    Should we do a factory reset? Is it worth it?
  8. Sakib4
  9. kotalkar
    Donut Apr 22, 2021
    Why not? In any case, you have to backup data...
    How can u even downgrade?
    OnePlus staff member said that this will be fixed with next update
