19
Procedure to Get the Pill-Shaped Home Button and Navigation Gestures for Android Pie in OnePlus 3/3T
  1. Singh is Kinng
    Gingerbread Apr 23, 2019
    Singh is Kinng , Apr 23, 2019 :
    Which app did you use to enable the default Android Pie gestures? Also would this app work on the 3T?
    Been trying to find an app that will work on a 3T but can't seem to find one.
  2. athaarv
    Jelly Bean Apr 23, 2019
    athaarv , Apr 23, 2019 :
    I use the 3T, but you need to be rooted in order to use it. It's called 'jOnePlus tools'
    Singh is Kinng likes this.
  3. RogerOriginals
    Ice Cream Sandwich Apr 23, 2019
  4. Singh is Kinng
    ah ok. I am non rooted on my 3t.
    Thx for the speedy response though.
  5. athaarv
    Do bear in mind that it's the stock Android gestures, not OnePlus's own implementation of gestures. Even though you can hide the nav bar using the app for more screen, I prefer using hardware buttons.
  6. Singh is Kinng
    Has suggested by RogerOriginals, I'll probably give the XDA App a whirl
  7. Singh is Kinng
    Thx for the suggestion RogerOriginals. I have already downloaded the Pie navigation bar via this thread using ADB as I am not rooted. Have had no issues so far. Will give the app suggested a go and see how I get on.
    Do you have the free or premium version?, and how has your experience been if you have tested this?
    RogerOriginals likes this.
  8. athaarv
    I used the free version on Oreo once and it sucks lol
  9. RogerOriginals
    RogerOriginals , Apr 23, 2019 :
    I haven't used it yet, I don't even use the on-screen navigation bar as it eats up valuable screen space on my 3T, so I cannot tell you how it works. Maybe someone else will, if they have used it. I only made this thread for those who need that option without the need for installing an app.
  10. athaarv
    Why not just use the ADB commands in the OP to enable navigation gestures?
  11. Singh is Kinng
    Having a moment here. Is that the ADB commands as per RogerOriginals initial post or the link to the XDA website he posted further up/down (whichever you look at it)
  12. athaarv
    As per Rogers' post
  13. Singh is Kinng
  14. G_Chumlung_Limbu_eIVb
    Donut Apr 24, 2019
  15. smitha photos
    Eclair Apr 25, 2019
    smitha photos , Apr 25, 2019 :
    i get error message, the program can't stat because api-ms-win-crt-locale-I1-1-0.dll is missing from your computer. Try reinstalling the program to fix this problem.
    downloaded from the above link and extracted
  16. RogerOriginals
    Ice Cream Sandwich Apr 25, 2019
    RogerOriginals , Apr 25, 2019 :
    Which windows version do you have? And during which step did you get the error?
  17. smitha photos
    Eclair Apr 25, 2019
    win 7 ultimate 64 bit
  18. RogerOriginals
    There's something missing in your computer, like a critical software to get this done. I'm not sure what will work, but try reinstalling Microsoft visual c++ redistributable and it might work. Google the link for that and download it.
    #38
  19. smitha photos
    Eclair Apr 25, 2019
    ok, i will try
    #39
  20. smitha photos
    Eclair Apr 25, 2019
    #40
