7
Proximity sensor in 6T
  1. JBlosser
    Donut May 20, 2019
  2. rainaksworld
    Cupcake May 21, 2019
  3. CSR!
  4. dineshbhat7
    Cupcake Jul 10, 2019
  5. Mr.seth
    Gingerbread Jul 16, 2019
  6. 61Hawaiiguy
    Cupcake Aug 27, 2019
    61Hawaiiguy , Aug 27, 2019 :
    My issue is, while talking the phone opens all sorts of stuff, drop down menu, battery info, turns on flashlight, shuts off data, wifi etc. It's impossible to stop this from happening, so far. Anyone have an fix yet?
  7. Stelian.zechiu
    Cupcake Aug 31, 2019
  8. Jitendra_Shrivastava
    Cupcake Sep 9, 2019
    Jitendra_Shrivastava , Sep 9, 2019 :
    I too have same problem. Phone doesn't get locked and it starts recording phone call or goes to hold or switch on speaker. I didn't had same problem with Motorola, MI, Samsung, iPhone phones.
    This is basic use of phone. Failing in basics leads to failure in future.
  9. kapooraviral
    Cupcake Sep 16, 2019
    kapooraviral , Sep 16, 2019 :
    I'm facing the same issue. When I'm on call the screen becomes operational and I end up recording the call or muting the call or putting the call on hold. is there an update which could help with this?
  10. E1569710089680
    Cupcake Sep 28, 2019
    E1569710089680 , Sep 28, 2019 :
    I've been suffering from this problem also. Love my OnePlus but hate this annoying issue. I've had apple phones for many years and was skeptical and worried making the detachment from Apple but I'm glad I did with the oneplus. Just wish it didn't have this issue. I keep launching all sorts of apps like timers and settings while I have the phone to my ear. I have to keep pulling the phone away and replacing back a few times before the screen goes off.
  11. luci78
    Cupcake Nov 7, 2019
    luci78 , Nov 7, 2019 :
    I have the same problem. I hope some new update will solve that annoying problem.
  12. G_Shrikant_Badghaiya_bnU
    Cupcake Dec 24, 2019
    G_Shrikant_Badghaiya_bnU , Dec 24, 2019 :
    Even, I am facing the same issue.p
    I bought OnePlus 6T on May2019.
    The pocket mode isn't working as expected.
    Some time phone gets unlocked in the pocket itself.
    Some times I found LED is turned on due to quick launch gesture, this should not happen in the pocket.
    Above all during call screen doesn't dim and when ear touches the screen, notification bar will slide OR with the touch of cheek phone go to mute or hold.
    I have used OnePlus 3T before, never faced this problem.
    Intresting thing is proximity sensor works for auto brightness control according to light conditions but doesn't work in pocket mode OR to Dim the display during call.
  13. G_Shrikant_Badghaiya_bnU
  14. hashimnouman
    Cupcake Dec 31, 2019
    hashimnouman , Dec 31, 2019 :
    Same issue here. Keep on muting my calls, putting them on hold and making calls to other contacts. Please resolve.
  15. G_Adir_Gadka_PciQ
    Cupcake Jan 4, 2020
    G_Adir_Gadka_PciQ , Jan 4, 2020 :
    Had the same problem until today with one plus 6 unit (new from the box).
    I have updated twice the device using the OTA update to Android 10 OxygenOS 10.3.0 and the issue seems to be resolved (it's not turning on the screen while talking, just when i put it infront of my face to look at something (as it should). will need a few days to verify this, will update.
