15
Proximity Sensor Issue during calls returned in 4.1.3
  1. Z_PROGRESS
    Cupcake Apr 18, 2017
    Z_PROGRESS , Apr 18, 2017 :
    I can't even install the update. downloaded the update and reboot, it asks me to find the update file, then after choosing the file , it gives a failed to update msg... 3 times and I gave up.
  2. bpwest80
    KitKat Apr 18, 2017
    bpwest80 , Apr 18, 2017 :
    Go to APK mirror, type in Google phone, then install the Google phone APK that says non-nexus. If you do that, you can install the Google phone the same way as a regular app. That's what I did m
  3. bpwest80
    KitKat Apr 18, 2017
    diaper. lol. I meant dialer..
    apersonnamedmike likes this.
  4. bpwest80
    KitKat Apr 18, 2017
    Are you talking about the 4.1.3 update or installing the Google phone apk?
  5. tejakgp
    Honeycomb Apr 19, 2017
    tejakgp , Apr 19, 2017 :
    Can you give the version no please?
  6. Vector
    Jelly Bean Apr 19, 2017
  7. G_Alejandro_Martín_Cova
    Donut Apr 19, 2017
  8. info2shail2010
    Ice Cream Sandwich Apr 19, 2017
  9. Endri_Matodashaj
    Gingerbread Apr 19, 2017
  10. mohmustaqeem
    Cupcake Apr 19, 2017
  11. Vector
    Vector , Apr 19, 2017 :
    I'm not rooted, but the google dialer posted in APK form in this thread from XDA seems to fix the issue. Hopefully OP will fix. Had the issue on 4.1.1 and 4.1.3
    Nimrodiny likes this.
  12. G_Ritesh_Munikar_JJXy
  13. Z_PROGRESS
    Z_PROGRESS , Apr 19, 2017 :
    the 4.1.3 update, now it's working, updated to 4.1.3 after waited a day. but it seems after the update that it's draining more battery, especially under mobile data.
  14. Z_PROGRESS
  15. F_Anand_Pradeep_duMM
  16. Z_PROGRESS
    don't mean to spam but one thing I left to mention is that besides noticeable more battery draining, the device is warmer than before when under the same usage as before the update
    and put in a specific. battery drained from 58% to 54% just after I post these reply under mobile data... US attached 4g LTE
  17. bpwest80
    KitKat Apr 19, 2017
    bpwest80 , Apr 19, 2017 :
    I just noticed my phone was staying awake a lot longer since installing the non-nexus version of the Google phone. Come to find out, the Google app is keeping the phone awake as long as I'm talking using the non-nexus Google phone app. Don't ask me why but I've tested it and the non-nexus Google phone apk is making the Google app keep the phone awake.
  18. bpwest80
    KitKat Apr 19, 2017
    You can see in the screenshots that I have 25 minutes of phone calls and that the Google app has kept my phone awake for 25 minutes. Google app usually only hold my phone awake for around 6 to 8 minutes through a full charge. It's up to 25 minutes already through less than 25% of my battery. It's all because of the Google phone non-nexus apk. If I switch back to the OnePlus phone it no longer holds the phone awake. I hate that because I was loving the Google phone.
    #38
  19. G_Alxs_pineda_vnmm
    #39
  20. Nimrodiny
    Nimrodiny , Apr 19, 2017 :
    That's very interesting! I've been using the same non Nexus version of Google dialer for the past few days and I've noticed that my standby time is worse, I lose around 9-12% of battery each night (approx 7 hours) when I used to lose only 5-7%. I guess that might be the reason :(
    I seriously don't want to go back to the stock dialer though, loving the Google one!
    Did you find a solution for this wakelock? BTW I have the Google app disabled.
    And one more question - did you find a way to make the stock Oxygen call UI circular image go away and replace it with the full screen Google one?
    Thanks mate!
    #40
    bpwest80 likes this.
