11
Proximity sensor issue one plus 7 pro
  1. schnc04
    Donut May 7, 2020
    #61
  2. G_Jeff_Merheb_qZnO
    Cupcake May 7, 2020
    G_Jeff_Merheb_qZnO , May 7, 2020 :
    Did you try to set all permissions of whatsapp to Allowed?
    With me ''Phone'' was not allowed, when I allowed it the bug disappeared, I think whatsapp was struggling and was confused to when to use the proximity sensor as long as it was not allowed. But it can be also any other permission that was not allowed that was bugging whatsapp
    #62
  3. schnc04
    Donut May 7, 2020
    #63
  4. G_Jeff_Merheb_qZnO
    Cupcake May 7, 2020
    Force close whatsapp and re-open it or restart the phone
    #64
  5. schnc04
    Donut May 7, 2020
    #65
  6. G_Jeff_Merheb_qZnO
    Cupcake May 8, 2020
    G_Jeff_Merheb_qZnO , May 8, 2020 :
    Did you also try the app I posted before? Also be sure to set battery to not optimize this app or it will stop after some minutes. It's working flawlessly for 48h already on my 7 pro
    #66
  7. schnc04
    Donut May 8, 2020
  8. Midhunsebastian
    Eclair May 11, 2020
    Midhunsebastian , May 11, 2020 :
    I tried ..it worked.thank you
    #68
  9. Vimal28
    Cupcake May 19, 2020
    Vimal28 , May 19, 2020 :
    Can somebody put this on notice of community manager. No solution of this very annoying problem
    #69
  10. Midhunsebastian , via OnePlus 7 Pro , Jul 1, 2020 :
    When i gave all permissions it worked for some.days. now its back. Same issue. I have to play an audio 10 time minimum to hear the voice fully. Really annoying. The same issue is also with instagram
    #70
  11. Paulo Viana
    Gingerbread Jul 10, 2020
    Paulo Viana , Jul 10, 2020 :
    [QUOTE = "Vimal28, post: 21620404, membro: 2053924"] Alguém pode colocar isso em aviso do gerente da comunidade. Nenhuma solução para este problema muito irritante [/ QUOTE]Will NEVER be solved
    #71
  12. Amir.Halim
    Cupcake Oct 22, 2020
    Amir.Halim , Oct 22, 2020 :
    Thats a deal breaker of OP7 Pro. There must be a way to fix this even by disabling the sensor to avoid the accidental hang-ups when the sensor decides to turn on the screen while it touches your face
    #72
    Mario Bros likes this.
