Proximity Sensor issues - Oneplus 8 Pro via OnePlus 8 Pro
  1. g.fiad
    Froyo Aug 1, 2021
    g.fiad , via OnePlus 8 Pro , Aug 1, 2021 :
    I'm having issues with the proximity sensor on my Oneplus 8 Pro.
    It's common during calls that the device register not intended commands.
    Please help me solve this annoying issue.
    G1629052499627 likes this.
  2. Does!Compute
    KitKat Aug 1, 2021
    Does!Compute , Aug 1, 2021 :
    While not a proper solution, it does help if I place the phone near my left ear instead of right during a call. The placement of the proximity sensor is such that the left ear is better suited for calls. The sensor is placed to the right of the top speaker, so it faces the side of your head while on a call, if you place the phone near your left ear.
    Aaron2017 and g.fiad like this.
  3. g.fiad
    Froyo Aug 1, 2021
    I'll try to do that.
    Let's see if I can change a long habit.
    Does!Compute likes this.
  4. Does!Compute
    KitKat Aug 1, 2021
    I do get that. It's tough to change it. I haven't been able to. And it's a bigger hassle at night, with the minimum brightness still bright enough to strain your eyes, as the screen is visible around the corners.
    Aaron2017 likes this.
