Pubg bag icon got stuck in my oneplus 5's display, visible on white backgrounds.
  1. ramky40
    Cupcake Aug 5, 2019
    ramky40 , Aug 5, 2019 :
    my OnePlus 6 device also got same issue.. is it changing display only option or any other options there
  2. Matt 80
    Lollipop Aug 5, 2019
  3. samikojo
    Froyo Aug 5, 2019
    samikojo , Aug 5, 2019 :
    Of course if it doesn't bother you too much changing the display is not necessary. At least you should lower your screen's brightness and if possible move that icon to some place else so that it won't get worse. There is no way getting rid of that burn other than changing the display.
  4. Lipunsubha
    Cupcake Sep 2, 2020
    Lipunsubha , Sep 2, 2020 :
    I have everything from PUBG is burned on the screen. The map, player info, bag, guns, scope almost everything. But it is only noticeable when the screen is white. Its annoying af but cant help.
  5. Lipunsubha
    Cupcake Sep 2, 2020
    No dont move icons often else it will create another burn on screen. I have two bags burn on the screen from pubg. You better lower the brightness and change wallpapers frequently.
