2
Pubg lag
  1. abhibnl Ice Cream Sandwich Jan 31, 2019
    abhibnl, Jan 31, 2019 :
    PubG is not optimized for S820. This chip is not used by any recent device. S660 is similar to S820, uses almost same Kryo architecture but PubG can run 60fps on this chipset. Reason? The developers have optimized the game for this chipset still being released on new devices. See, it's simple. The developers will invest time in something they will get profit from. S820/821 is obsolete now. No one will develop or optimize specifically for it. Accept the reality and buy a latest device.
    if you are claiming that it's running fine on custom ROM, then use a custom ROM and don't create threads here. We will what optimizations Pie brings along once its released but don't expect double frame rate with a software update. The developers need to optimize game code/graphics for the S820/821 platform.
    O1548963317124 likes this.
  2. O1548963317124 Donut Jan 31, 2019
    O1548963317124, Jan 31, 2019 :
    well,but I can't believe the fact.still ny questions is this .2Gb ram and sd 620 is the minimum specs for playing pubg. then why its still lag on 6gb ram and 821 sd
    G_Ta_Wreck_mKyz likes this.
  3. Sujay_kolhe-69 Gingerbread Jan 31, 2019
    Sujay_kolhe-69, Jan 31, 2019 :
    820/821 -> quad core -> more heat produced -> thermal throttle -> reduced unstable performance
    625,660,835,845 -> Octa core -> less load -> less heat -> no throttle -> max performance -> smooth ,stable fps
    810 was an octa core too thats why 820/821 are failures of snapdragon
    i really dont know how to be more clearer than this^^
    G_Ta_Wreck_mKyz and pramantiwari like this.
  4. abhibnl Ice Cream Sandwich Feb 1, 2019
    abhibnl, Feb 1, 2019 :
    First, RAM is not a limiting factor on OP3. I want you and many others who always say "my device has 6GB ram why it lags". RAM has nothing to do with PubG lagging.
    Like I mentioned above, each new project/game is developer keeping several chipsets in mind for reference as to how they would perform on myriad of devices working on same chipset. Android, unlike iOS, is fragmented as *** and there are 10s of models with a certain chipset e.g. S660.
    2nd - S820/821 is now a 3 generations old chipset so no game company will invest time in developing and optimizing for this CPU and its instruction set/code/cores or whatever you want to say it.
    Last and the most important factor - PubG works best on 8-core CPUs. i am talking about the Android version because iOS has metal API implemeted on all graphics applications and this reduces overhead on CPU ALOT!
    So unless you have a 8-core CPU and fairly modern chipset (not more than 1 year old), your game is optimized and will run fine. I played it on a OP6 and i couldn't believe how gorgeous this game looks on HDR at 60fps. So accept that fact that S820/821 is an old chipset now and no game developer will bother optimizing a game for its quad-core architecture. Enjoy whatever you have or go & buy a new gen device :)
  5. toastytoast1234 Marshmallow Feb 1, 2019
    toastytoast1234, Feb 1, 2019 :
    I have no idea why people continue to answer when you just won't listen to them or accept reality.
    I don't know how you even manage to play in the first place with 2 fingers permanently stuck in your ears.
  6. O1548963317124 Donut Feb 1, 2019
  7. toastytoast1234 Marshmallow Feb 1, 2019
  8. Ranjithstar256 Donut Feb 10, 2019
    Ranjithstar256, Feb 10, 2019 :
    guys the problem is with the pubg server only. the problem is with the app only . I'm using OnePlus 6 . even after factory resetting also it's still lagging. might be it is because the userbase is increased. try deletiNg frds.I hope pubg works well in the next updates.
  9. Ranjithstar256 Donut Feb 10, 2019
    no help in pie also!
    op6
  10. Ranjithstar256 Donut Feb 10, 2019
    Guys!!!!!!
    Finally I figured out what is the issue and solved it!!
    The problem is with the friends list. You have more than 300 game frds! And many in your clan and your Facebook frds too! Delete all the frds except like 20 who are very close. Logout and login using Google play games so that it will not load your fb frds. Leave the clans if possible. That's it game works awesome [e]1f44d[/e] previous I tried upto factory resetting my entire mobile!! Factory resetting also didn't helped later I realized problem is inside the app. Okay if you don't want to take risk first of all log out and play as guest you will realize [e]1f44d[/e][e]1f44d[/e] respond me if it helped.. Thanks ranjithstar256@gmail.com [e]1f44d[/e] from op6
