pubg mobile cant play using mobile data after android 10 via OnePlus 7 Pro
  1. adrian08
    Cupcake Oct 23, 2019
    adrian08 , via OnePlus 7 Pro , Oct 23, 2019 :
    hello..after updating my OP7pro to android 10,i cant play pubg mobile using mobile data,but only by wifi,eventhough mobile signal is strong..did anybody have the same problem?only pubg mobile that have this kind of problem,other game is ok..why is this happening?anyone can help?
  2. #2
  3. adrian08
    already done that,clear data,clear cache,even uninstall then install back..still have same problem[e]1f61e[/e]
  4. Narayan_Shrestha , via OnePlus 7 Pro Almond , Oct 23, 2019 :
    Then something must be wrong with your network or the game itself. Nothing wrong with Oxygen OS. Maybe resetting you phone could work.
  5. H1571925735391
    Cupcake Oct 24, 2019
  6. Prabhu Narayanasamy
    Gingerbread Oct 24, 2019
  7. the_o2
    Marshmallow Oct 24, 2019
    the_o2 , Oct 24, 2019 :
    Press and hold that app, click on app info and click on data usage and check whether the 'DataUsage disabled' is enabled if so then disable it.
