15
PUBG Mobile Notch Problem!
  1. Rishabh_Pandoh
    Gingerbread Aug 16, 2019
    Rishabh_Pandoh , Aug 16, 2019 :
    Guys, just turn off the notch before starting the game and you're good to go, you can revert back to the notch after the game.
    Setting>Display>Notch Display
    ShivamKrishn likes this.
  2. Aadimanav
    Eclair Aug 17, 2019
    Aadimanav , Aug 17, 2019 :
    tried disabling the notch still there is gap on both the sides of the screen. thats why i am playing in normal.
  3. ShivamKrishn
    Cupcake Aug 17, 2019
    ShivamKrishn , Aug 17, 2019 :
    Yes hiding notch display worked! But there are still issues, these now happens less frequently.
  4. Aadimanav
    Eclair Aug 17, 2019
  5. ShivamKrishn
    Set notch setting to normal in pubg and let me know
  6. Aadimanav
    Eclair Aug 17, 2019
    if i set my pubg setting normal. thn it works fine. but not with the phn settings
  7. ShivamKrishn
    In my case right side area which helps to move camera angle in pubg, gets freezed only left area works. Right area works again when you lift finger and try again.
  8. Aadimanav
    Eclair Aug 17, 2019
    yes i know about this. but this has to be done in micro seconds. untill its done u are killed [e]1f602[/e]
  9. ShivamKrishn
    It happens till u lift finger and touch again.
    Aadimanav likes this.
