PUBG Screen in background always.
  1. Waveform Modifier Marshmallow Jul 21, 2019
    Waveform Modifier, Jul 21, 2019 :
    Use your phone however you like. But again, no company on earth will ever give you repeated replacement because of user caused damages.
    #41
    Kytharsis likes this.
  2. Sushant_Patil556 Cupcake Jul 21, 2019
    #42
  3. Vikass1102 Cupcake Jul 22, 2019
    Vikass1102, Jul 22, 2019 :
    again.. it's not caused by the user.. it's company's manufacturing defect. because it's caused due to internal damage..
    #43
  4. Waveform Modifier Marshmallow Jul 22, 2019
    Waveform Modifier, Jul 22, 2019 :
    Nope. Wrong.
    #44
  5. B_Wrath Marshmallow Jul 22, 2019
    B_Wrath, Jul 22, 2019 :
    Can you prove this or provide data to support this?
    #45
  6. Vikass1102 Cupcake Jul 22, 2019
    i don't have to. Because the company has nowhere mentioned in any T&C about the screen replacement under warranty caused due to over usage of any third party app causing screen burn will not be recovered.
    #46
  7. Liehjan KitKat Jul 22, 2019
    Liehjan, Jul 22, 2019 :
    You should watch this video, he's explaining it really well!
    #47
  8. B_Wrath Marshmallow Jul 22, 2019
    Well. You have to.
    The limited warranty does not cover:
    • Defects or damage resulting from accidents, neglect, misuse or abnormal use; abnormal conditions or improper storage; exposure to liquid, moisture, dampness, sand, or dirt; unusual physical, electrical or electromechanical stress.
    You need to prove that the screen burn in doesn't fall under abnormal use.
    #48
  9. Vikass1102 Cupcake Jul 22, 2019
    #49
  10. Horsault Marshmallow Moderator Jul 22, 2019
    Horsault, Jul 22, 2019 :
    It would be manufacturing defect if your device came to you with burnt screen.
    But of course you received a normal screen, that got burnt by your using it. The proof is, so many OP6/OP6T users whose screen will never burn because they don't display fixed images for infinite time.
    As you're not into your device, this isn't either caused by internal damage, but by external cause.
    #50
